HELP!! 440 Distributor, Head Clereance
Electrical and Ignition
  1. josekh7
    josekh7 Well-Known Member
    88
    0
    Apr 26, 2013
    los angeles
    Local Time:
    9:45 AM
    Guys, need your help i bought a pertronix distributor and found out my edelbrock heads and distributor dont fit. I had to grind a little off the head to force fit it. Do any of you guys know of a distributor preferably billet that can use my pertronix ignitor module, and uses vacum advance and mostly fit??
  2. fishfly
    fishfly Well-Known Member
    61
    15
    Jul 23, 2017
    usa
    Local Time:
    12:45 PM
    I'm pretty sure the mallory unilite will take that module but verify to be 100% sure. The unilite works with EB rpm heads. My unilite doesn't have vaccum advance though
  3. josekh7
    88
    0
    Apr 26, 2013
    los angeles
    Local Time:
    9:45 AM
    Anyone?
  4. josekh7
    88
    0
    Apr 26, 2013
    los angeles
    Local Time:
    9:45 AM
    Fishfly, thank you i cant find one with vacum adv :(
  5. famous bob
    famous bob mopar misfit
    11,808
    3069
    Aug 14, 2011
    okla
    Local Time:
    11:45 AM
    Don`t feel pregnant ! You wouldn`t believe how much I had to take off my raised port heads to get a fast fuel. inj. dist. to work. They used a chevy/short dist., w/ a Chrysler flat on the shaft !
    Anyone going that route, go w/ an MSD locked dist. !!
  6. josekh7
    88
    0
    Apr 26, 2013
    los angeles
    Local Time:
    9:45 AM
    Lockedout? Wouldn't you want your timing to advance at higher rpms?
  7. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    37,201
    19440
    Jan 18, 2006
    Iowa
    Local Time:
    11:45 AM
    I used to sell Mallory distributors for that reason. They would work in the RB's. Carry on.
  8. josekh7
    88
    0
    Apr 26, 2013
    los angeles
    Local Time:
    9:45 AM
    So i get Mallory works but is there any with vacuum advance that will also work?
