Help I D small block heads.
Discussion in 'Small Block Mopar Engine' started by RAT ROD AL, Jan 11, 2019.
  1. RAT ROD AL
    RAT ROD AL FABO Gold Member FABO Gold Member
    805
    574
    Jan 18, 2013
    St. James City. FL.
    View My Photos
    Local Time:
    3:06 AM
    I have a pair of small block heads that I got a few years back. Had run them through the machine shop, Had 2.02 valves installed, guides ect. Just wondering how good of a head they are for just a street car. I see 360 cast in the runners under the valve covers along with ( best I can make out) is 3418915 on both . Any help would be appreciated, Thanks AL
  2. Mtrhead
    Mtrhead Well-Known Member
    559
    70
    Sep 19, 2018
    S.C.
    Local Time:
    3:06 AM
    It's a J head very desirable 340/360 head
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • Alaskan_TA
      Alaskan_TA Well-Known Member
      4,092
      1853
      Nov 12, 2004
      PA
      Local Time:
      3:06 AM
      Ignore the letter.
      915 heads can have J, O, U or Z letters but they are all 915 castings.
      On 340s, 2.02 intakes, smaller on 360s.
      Some were also used on the AARs & T/As with offset intake push rod holes.
      • Like Like x 1
      • RAT ROD AL
        805
        574
        Jan 18, 2013
        St. James City. FL.
        View My Photos
        Local Time:
        3:06 AM
        I've seen X and J cast in other heads by the spark plug hole ,but don't see any on these. Thanks for the info guys
      • Locomotion
        Locomotion Well-Known Member
        2,686
        248
        May 31, 2004
        Florida
        Local Time:
        3:06 AM
        X heads were only 894 heads. The 915 heads were the original 360 heads, but also used on 340's starting in 1970, but machined according to application/year.
        Only bad thing about 2.02" heads is that you don't know how many valve jobs they've already had. That sinks the valve & seats and reduces flow. Taking the same 915 head with 1.88" intakes and machining them for 2.02" will provide a nice, fresh, high seat and can be made more consistent through them all.
        • Like Like x 1
        • Agree Agree x 1
