1. Steve Agrella
    Steve Agrella Well-Known Member
    443
    113
    May 4, 2018
    Mission Hills Ca
    Local Time:
    10:48 PM
    Torn on which way to go, I have a 74 Duster with a stock steering box that is pretty sloppy, I want to upgrade it with a firmer feel for the street it’s a daily driver.
    I’ve been looking at Borgeson, tight feel and the red head, however don’t know which way to go, I’m leaning towards the borgeson for ease of installation, lighter and smaller but frigging pricey.
    Any suggestions or opinions pros or cons with each would be greatly appreciated
    • Like Like x 1
    • Murray
      Murray FABO Gold Member FABO Gold Member
      1,700
      1100
      Apr 19, 2010
      San Jose, California
      Local Time:
      10:48 PM
      Power steering or manual? What do you mean by "sloppy"?
    • 66fs
      66fs FABO Gold Member FABO Gold Member
      4,673
      1399
      Sep 9, 2009
      Greenwood, South Carolina
      Local Time:
      1:48 AM
      Firm Feel rebuilds boxes. The rest of the steering must be tight. Tie rod ends, Pitman arm, Idler arm, Ball joints, Bearings adjusted, and a good alignment. You can also use a weaker pressure spring in the pump.
    • j par
      j par Well-hung Member
      22,832
      11466
      Jul 2, 2014
      Portland Oregon
      Local Time:
      10:48 PM
      you're soon becoming one of my favorite for a body only member LOL every time you ask a question it seems like instead of an answer you get 20 questions asked to you!
    • 65 Dartman
      65 Dartman FABO Gold Member FABO Gold Member
      11,233
      2892
      Sep 24, 2006
      Strasburg, VA
      Local Time:
      1:48 AM
      Steer and Gear also does both manual and PS rebuilds. They offer 4 different stages of firmness on thei PS box rebuild. I’d recommend their Stage III which should be comparable to that offered by Firm Feel
    • TrailBeast
      TrailBeast AKA Mopars4us on Youtube
      21,329
      8841
      Mar 11, 2011
      Arizona
      Local Time:
      10:48 PM
      You have already tried adjusting yours?
      • Agree Agree x 1
      • Steve Agrella
        443
        113
        May 4, 2018
        Mission Hills Ca
        Local Time:
        10:48 PM
        Yes tried adjusting it,
      • Steve Agrella
        443
        113
        May 4, 2018
        Mission Hills Ca
        Local Time:
        10:48 PM
        Sorry Power steering, what do I mean by sloppy, there's play in the box that I can’t adjust out.
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
        18,208
        6456
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        12:48 AM
        And you never will, that is how they are built.
        What you may be feeling is the torsion sensing system, that determines how much boost to provide based on how far and how fast you are turning the steering wheel.
        It is real easy to change that though. The part that makes it SEEM sloppy is called a reaction spring. You can buy a package of 5(IIRC) of those at the dealer, and slam 3 of them in there in a couple of hours. It will get rid of that over-assist and mushy feel at the same time.
        • Like Like x 1
        • Steve Agrella
          443
          113
          May 4, 2018
          Mission Hills Ca
          Local Time:
          10:48 PM
          The play I’m feeling is from the center position of the steering wheel, I have an inch play both ways from center.
          Everything in the front end is new except the box
        • AJ/FormS
          18,208
          6456
          Jan 19, 2014
          Local Time:
          12:48 AM
          An inch either way is very good.
          • Like Like x 1
          • j par
            22,832
            11466
            Jul 2, 2014
            Portland Oregon
            Local Time:
            10:48 PM
            Have you rebuild the steering coupler?
          • Mike69cuda
            Mike69cuda 64 is the new 17 FABO Gold Member
            1,472
            1095
            Jan 2, 2018
            Overland Park Kansas
            Local Time:
            12:48 AM
            AJ - Is it hard to change reaction springs? Can I do it with the box still in the car? My power steering works ok, but has zero road feel.
          • j par
            22,832
            11466
            Jul 2, 2014
            Portland Oregon
            Local Time:
            10:48 PM
            I meant this legitimately because I've had trucks that have Heavy Wheels and make that coupler wear out so it's a possibility.
          • Peter Bates
            Peter Bates 1973 Cuda owner for 36yrs
            137
            109
            Aug 25, 2018
            Sylvania ohio
            Local Time:
            1:48 AM
            I went with the Firm Feel stage 3. It's tight and steers great. Plenty of power assist and not over assisted like the original. They offer the coupler rebuild kit as well. Call Matt and speak to him.
          • AJ/FormS
            18,208
            6456
            Jan 19, 2014
            Local Time:
            12:48 AM
            I hear you on the over-boosted road feel.
            No I doubt you can do it in frame,at least not without the factory nut-tool,and you would have to remove the column; but the box drops out the bottom pretty easy, even with Headers. Watch out it is surprisingly heavy. I only added 2springs the first time and a week later I added a third. IMO it's best to have the box in a vise, but even that is optional. While it's out this is a good time to put new seals in it.
            The FSM tells you to use certain specialty tools , but I got away without them. Honestly that box is real simple. Once it is on the bench, you can have it apart in minutes.
          • KosmicKuda
            KosmicKuda FABO Gold Member FABO Gold Member
            1,752
            547
            Jan 15, 2011
            N Ohio
            Local Time:
            1:48 AM
            Even when these cars were brand new that's how it was. You could drive a car with one finger and not feel a thing. Oh, unless your honey was snuggled up beside you on the bench seat.
            • Like Like x 1
