Help needed on crager ss
Tires and Wheels (Mopar Hubcaps Too)
  1. tekslk
    tekslk Well-Known Member
    3,111
    34
    Dec 13, 2009
    McClure, Pa
    Local Time:
    10:50 PM
    Im getting 4 15x6 crages SS wheels for my 67 barracuda, My question is what size tires and kind would look good on these? The car has stock suspension. 360 with 8 3/4 355 gears.
  2. pettybludart
    pettybludart Well-Known Member
    15,741
    109
    Jul 18, 2008
    Ontario,Canada
    Local Time:
    9:50 PM
    215 up front,235 on back.JMO
  3. VDART
    VDART Well-Known Member
    5,669
    42
    Jul 23, 2006
    heizer ks
    Local Time:
    9:50 PM
    Need to know the back space--- look at the threads with 15x7 dart /cuda wheels -- it will give you some ideas.
    How big of a tire are you trying to stuff? Lawrence
  4. Oklacarcollecto
    Oklacarcollecto Life is an experiment
    17,339
    283
    Mar 13, 2009
    North Central Oklahoma
    Local Time:
    9:50 PM
    Xs2... JMO also.
  5. tekslk
    3,111
    34
    Dec 13, 2009
    McClure, Pa
    Local Time:
    10:50 PM
    Just nice looking would a 235/60/15 work all the way around then I can rotate them.
  6. Oklacarcollecto
    17,339
    283
    Mar 13, 2009
    Local Time:
    9:50 PM
    I think those would be too big for the front. Maybe others will chime that have tried it with the results.
  7. tekslk
    3,111
    34
    Dec 13, 2009
    McClure, Pa
    Local Time:
    10:50 PM
    3.375 back spaceing.
  8. pettybludart
    15,741
    109
    Jul 18, 2008
    Ontario,Canada
    Local Time:
    9:50 PM
    Rotate them?How many miles do you drive the car per year?I only ask because I can,t rotate my 215,245 tires and it,s been 3 years LOL.You might beable to go 215 all around,but would look small on the rear.If alignment is true,I doubt you,ll have much wear with minimal driving.JMO:D
  9. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,453
    1292
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    9:50 PM
    ..............u could always switch them from side to side...........kim.........
  10. tekslk
    3,111
    34
    Dec 13, 2009
    McClure, Pa
    Local Time:
    10:50 PM
    It took 4 years for the last set alignment great but I rotate to keep them looking the same, seams the back keep wearing down for some reason. Ocassional smoke run you no.
  11. Oklacarcollecto
    17,339
    283
    Mar 13, 2009
    Local Time:
    9:50 PM
    Hmmmm. Sounds like you need to buy 6 tires... so you will have a spare set for when the back ones have left too much of their life on the pavement.
  12. tekslk
    3,111
    34
    Dec 13, 2009
    McClure, Pa
    Local Time:
    10:50 PM
    Thats not a bad idea then I need 2 more small bolt pattern wheels that are getting hard to find.
