Help needed - outer diameter AC lines
Heating / Cooling / AC
  1. Machmeter1
    Machmeter1 FABO Gold Member FABO Gold Member
    1,067
    417
    Aug 16, 2019
    Dayton Ohio
    Local Time:
    6:05 AM
    For my AC restoration project, I would need the outer diameter of two AC lines for a 69 Barracuda. Both are metal AC lines, one line runs along the passenger side fender from the drier to the AC expansion valve and the other line runs on the driver side fender, from the compressor through the radiator support panel to the condenser.
    Thank you and Merry Christmas,
    Wolfgang
  2. g413
    g413 Well-Known Member
    515
    125
    Aug 26, 2014
    Fresno, CA
    Local Time:
    5:05 AM
    On my 67 Barracuda, the liquid line (to the TXV) is 3/8" OD and the hot gas line is 1/2" OD.
    • Like Like x 1
    • Machmeter1
      1,067
      417
      Aug 16, 2019
      Dayton Ohio
      Local Time:
      6:05 AM
      Thank you Sir, that is exactly what I needed to know.
      Wolfgang
