1. nodemon
    nodemon Well-Known Member
    441
    126
    Mar 21, 2015
    St.Louis
    Local Time:
    12:29 AM
    0919211308c.jpg 0919211308c.jpg 0919211308e.jpg 0919211313.jpg 0919211312i.jpg 73 318 engine in my 72 Demon.
    I've asked plenty of dumb, newbie questions here and those that have answered have helped me out as I'm learning and bringing my Demon back to life.
    I bought this car not running, but told, "it ran" . For some reason the engine was pulled to replace the clutch and when engine was set back in, all accessories were left off.. It did turn over by hand.. Anyway, I purchased a set of fresh rebuilt 302 casting heads..an Edelbrock LD4B intake and an Edelbrock 650cfm. carb. Pulled the heads and intake off the engine to swap these out and discovered some dense sludge, several bent push rods with a couple having some of the metal scraped off and evidence of a couple of valve kissed pistons.. nothing too bad or deep, but they definitely touched.
    My question is, and realize without seeing yourself and other factors, it'll be hard to answer, but some of you have seen enough of this to possibly help... Do the bent push rods indicate a major issue..? Do pistons automatically need to be replaced with minor valve indents.. ? At this point, should I just pull the short block out and rebuilt it..?
    If I do rebuild it, do the cylinders have to be bored or just honed..?
    Thanks in advance for those that I know will help.. You guys are awesome..! Understand that I'll probably have plenty more questions after some answers start coming in. lol
  2. Dana67Dart
    Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
    7,501
    5140
    Jul 16, 2017
    Northern Colorado
    Local Time:
    11:29 PM
    Probably the pistons are ok,
    Rhe sludge is indicitave of a poorly maintained engine, so bearings would be suspect.
    If time and finances are available might as well rebuild before you put the new parts on it.
    Hone vs bore will only be known after engine is inspected with bore gauge.
    • Agree Agree x 3
    • nodemon
      441
      126
      Mar 21, 2015
      St.Louis
      Local Time:
      12:29 AM
      Thanks for your response..!
    • Murray
      Murray FABO Gold Member FABO Gold Member
      2,551
      1837
      Apr 19, 2010
      San Jose, California
      Local Time:
      10:29 PM
      I have never seen pistons with such small valve reliefs and am suspicious of cam "lift" or cam chain stretch. Bent push rods confirm this. I am not trusting anything about this motor and would only be happy tearing this motor down and starting over again. Sorry, just my opinion.
      • Like Like x 1
      • Agree Agree x 1
      • 1966Post
        1966Post Well-Known Member
        286
        103
        Mar 8, 2015
        Wisconsin
        Local Time:
        12:29 AM
        I concur with Murray. Take it apart once and do it right. In the end you’ll be happier
        It’s usually also cheaper to do it right once than wrong and then right…..
        • Like Like x 1
        • Agree Agree x 1
        • nodemon
          441
          126
          Mar 21, 2015
          St.Louis
          Local Time:
          12:29 AM
          No, I think you're right.. Smart thing to do is rebuild.. Those valve reliefs are not reliefs at all.. Valve strike..
          • Agree Agree x 1
          • cudamark
            cudamark FABO Gold Member FABO Gold Member
            8,989
            1457
            Mar 14, 2009
            San Diego
            Local Time:
            10:29 PM
            The cam doesn't look all that great either. I'd pull it down and start over.
            • Agree Agree x 1
            • nodemon
              441
              126
              Mar 21, 2015
              St.Louis
              Local Time:
              12:29 AM
              What on the cam are you seeing..? I wasn't sure what to look for.
            • cudamark
              8,989
              1457
              Mar 14, 2009
              San Diego
              Local Time:
              10:29 PM
              The wear, deposits, a bit of pitting.....
              • Like Like x 1
              • toolmanmike
                toolmanmike Moderator Staff Member FABO Gold Member
                61,510
                50125
                Jan 18, 2006
                Iowa
                Local Time:
                12:29 AM
                Those aren't valve reliefs the valves ran into the pistons. Wrong cam, cam timing, timing chain etc. You need to be careful with flat tops.
                • Agree Agree x 1
                • TT5.9mag
                  TT5.9mag Two atmospheres are better than one
                  1,784
                  1774
                  May 5, 2016
                  So cal
                  Local Time:
                  10:29 PM
                  For someone just learning (key piece of information) here is my advice. Buy another engine and keep that one as a tool. You could probably pick up a magnum 318 for cheap, slap your accessories on it, with a new intake, and have the car running in a weekend. Then use that engine as a classroom, tear it down and teach yourself how to build an engine correctly when youre in no hurry to get it back in your car. Just a thought.
                  • Agree Agree x 1
                  • nodemon
                    441
                    126
                    Mar 21, 2015
                    St.Louis
                    Local Time:
                    12:29 AM
                    Yep, I'm actively looking for one now.. !
                  • toolmanmike
                    61,510
                    50125
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    12:29 AM
                    Exactly. I don't see much reusable here if you want to do it right.
                    • Like Like x 1
                    • 65TerrorCuda
                      65TerrorCuda Well-Known Member
                      412
                      61
                      Jul 26, 2009
                      Albuquerque, New Mexico
                      Local Time:
                      11:29 PM
                      Missed a gear, overrevved, valves hit pistons and bent pushrods. Bend em back straight, reassemble and drive if funds are tight. My uncle did this exact thing in the 60's in his Barracuda.
                      Not saying you should though
                    • RustyRatRod
                      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                      78,159
                      55767
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      1:29 AM
                      Someone probably over revved it playing around and valves floated and hit pistons. I would recommend pulling it and going through the short block, if for no other reason than to get everything machine shop clean. That way, you've not wasted good money on rebuilt heads going on a crappy short block.
                      Plus, you can decide if you want to upgrade the camshaft, to go with the stellar induction system you've chosen. You will want to have the matching valve springs installed on your heads, as the springs need to match the camshaft. The Comp 901-16 spring will handle anything you will ever want to put in that's under about .500 lift and they're very affordable. I would even add in some budget headers and that would make for a really nice little engine.
                      I would recommend something like the Lunati High Efficiency series. Something like this one.
                      https://www.lunatipower.com/high-efficiency-hydraulic-flat-tappet-cam-chrysler-273-360-268-268.html
                      • Like Like x 1
