Help! Radiator mounting bolt dimension
340swinger4spd
Beldenville WI
So I am replacing my driver side core support but I need the radiator mounting bolt dimensions. So left to right and opposite corner to opposite corner. I don't have a radiator yet and the old panel was damaged from an accident. If anyone has those measurements I would be very grateful.
OK here's what I have : left to right 23 3/4" bolt centers, top and bottom . Overall measurement of a 22" radiator is 25 1/8-25 1/4". that is for a 22" radiator with A/C . Hope this helps . Tom
Do you have bottom corner bolt center to top corner bolt center and vice versa? This way I can make sure the radiator is level left to right.
Yup , I do . I assume that the right side is o.k. It should read from top hole to bottom hole 14". Left side , top to bottom is 14 3/4". the bottom holes are offset . The top holes are straight across . FYI core size is 22"wide x 17 1/8"high x 1 3/4" thick . Overall radiator measurement is 25 3/8" wide x 21 5/8" high
