Help! Small block 360 has a knocking sound
Small Block Mopar Engine
  1. MOPAROFFICIAL
    MOPAROFFICIAL Well-Known Member
    4,561
    3548
    Jun 1, 2016
    Between a tit and an armpit
    Local Time:
    10:50 AM
    Pull the cover and run it to see if the noise is still there.
    The baffling comes loose on those cover sometimes and the rockers hit...they can be screwed on or pinned/riveted.
  2. CheeseRules01!
    CheeseRules01! Well-Known Member
    72
    9
    May 25, 2015
    West Fork,AR
    Local Time:
    12:50 PM
    The noise is still there with the covers off, I think it is a valve train issue with number 5. I need to pull the head off at some point and check the valves.
  3. 1970 TA
    1970 TA Member
    23
    11
    Jun 26, 2017
    illinois
    Local Time:
    12:50 PM
    I'm thinking flexplate bolts.
    My 340 sounded just like your motor.
    Bolt holes elongated in the flexplate.
    • Agree Agree x 3
    • Like Like x 1
    • CheeseRules01!
      72
      9
      May 25, 2015
      West Fork,AR
      Local Time:
      12:50 PM
      Ok guys, I made a stethoscope and tested all kinds of different spots on the engine for noise. The engine checked out fine. I checked the fuel pump, as you guys mentioned, I checked the valve covers, the heads, none of it was making noise. I even put it on the oil pan just to see if there was anything going on in the bottom end, again, nothing. However, when i crawled underneath and put it on the bell housing, you can hear the knock clear as day, on both sides of the car. I checked the flex plate bolts, all of them are nice and tight. Didn't see any cracks on the flex plate, but there is an interesting thing I noticed, I think there is something wrong with the Transmission. When it is in park, the knock is there, but not very loud. Reverse, it practically disappears, you cant really hear anything at all. Neutral, it is atrocious, the video i recorded at the beginning of the thread was with the car in neutral. In gear, it is just as loud, but when you drive aggressively, it almost seems to go away. Part throttle or letting off the gas, it sounds hideous. I checked the transmission fluid, and for some reason there was almost none in there. Strange because I checked it not that long ago, and it was full. The car doesn't have any leaks that I know of, but I guess it obviously does for the tranny fluid to disappear like that. Didn't get a chance to add more, I don't have any extra at the moment, tomorrow I will get out there and fill the tranny back up and see what happens. Hopefully its not to badly damaged. I feel kinda stupid for running it low on fluid, but the weird thing is that it acted just fine. No slipping or anything, shifted normally as well. If you guys have any thoughts, please share them. Thanks.
    • diymirage
      diymirage HP@idle > hondaHP@redline
      16,901
      9987
      Oct 12, 2012
      michigan
      Local Time:
      1:50 PM
      What gear was the tranny in when you checked the fluid?
      • Agree Agree x 2
      • Like Like x 1
      • 408 swinger
        408 swinger FABO Gold Member FABO Gold Member
        1,351
        1094
        Nov 12, 2010
        Iowa
        Local Time:
        12:50 PM
        Crankshaft to flexplate bolts.
      • Cudafever
        Cudafever Well-Known Member
        3,436
        980
        Sep 27, 2009
        Local Time:
        11:50 AM
        Still say it in the flex plate. you may not be able to see the crack.
      • CheeseRules01!
        72
        9
        May 25, 2015
        West Fork,AR
        Local Time:
        12:50 PM
        Neutral
      • mbaird
        mbaird mbaird FABO Gold Member
        5,397
        2423
        Dec 10, 2005
        boise, Id
        Local Time:
        11:50 AM
        Park pawl ?
      • CheeseRules01!
        72
        9
        May 25, 2015
        West Fork,AR
        Local Time:
        12:50 PM
        If it was in the flex plate, then wouldn't it knock just as loud no matter what gear you are in? I'm not saying that I don't believe you guys, but it just doesn't quite add up. Like I said, the knocking is only there in certain gears, which is kinda strange.
      • CheeseRules01!
        72
        9
        May 25, 2015
        West Fork,AR
        Local Time:
        12:50 PM
        Could it causes noises in other gears though? I'm not sure.
      • yellow rose
        yellow rose Doctor of Thinkology.
        19,440
        15570
        Jun 19, 2015
        Living on the razors edge
        Local Time:
        10:50 AM
        Not always. Had a Ford that was 3.5 hours from and and I specifically told the customer to double check the flex plate/flywheel and look at it very close.
        A few days later he called and was going to pull it and send it back. I burned a day and drove to his shop and what did I find?? Several small fractures that would make noise in weird ways.
        Lost a whole day of making money. Look very close. Very close at that flex plate.
        • Agree Agree x 2
        • mbaird
          5,397
          2423
          Dec 10, 2005
          boise, Id
          Local Time:
          11:50 AM
          You will have to pull the trany . Might as well do it now vs spending more time diagnosing.
          • Agree Agree x 2
          • mbaird
            5,397
            2423
            Dec 10, 2005
            boise, Id
            Local Time:
            11:50 AM
            A crack may be hard to identify.
            Last year I was having a problem with falling and tripping while playing hockey. WTF ! I thought I was developing an equilibrium related illness !
            Turned out there was a crack in my blade tower that was hard to see but would flex under hard maneuvers .
          • CheeseRules01!
            72
            9
            May 25, 2015
            West Fork,AR
            Local Time:
            12:50 PM
            Thats the plan stan, in fact I have a 727 that I am going to freshen up to put in the car instead of the 904 that is in it now. So I was already planning on pulling the tranny at some point, I guess now I have a reason.
          • mbaird
            5,397
            2423
            Dec 10, 2005
            boise, Id
            Local Time:
            11:50 AM
            If thats the case you must be relieved to know its a trany issue !
            Whew!!!!
          • rustycowll69
            rustycowll69 Well-Known Member
            1,995
            866
            Feb 19, 2016
            Pacific northwest
            Local Time:
            10:50 AM
            one thing you might try before you pull the trans: try pulling and pushing forwards and back on the front dampener/crank pulley. There should be minimal slop.
            • Like Like x 3
            • Wyrmrider
              Wyrmrider Well-Known Member
              2,264
              1100
              Sep 5, 2016
              los angeles
              Local Time:
              10:50 AM
              yep bad thrust
            • CheeseRules01!
              72
              9
              May 25, 2015
              West Fork,AR
              Local Time:
              12:50 PM
              I did, there was absolutely no slop at all, nice and tight. I think my spring/summer project will be tearing it apart and fixing everything on the car. It'll be fun.
            • Cudafever
              3,436
              980
              Sep 27, 2009
              Local Time:
              11:50 AM
              My money is still on the flex plate.
              loosen you torque converter bolts and remove them. make sure that the converter will slide back into the transmission.
              should have about 1/4 or more clearance between the flex plate and the converter.
              Make sure the car is facing uphill so the converter stays put and START IT UP.
              Its only going to take 10 sec of run time to know if it there.
              • Like Like x 1
              • Agree Agree x 1
              • George Jets
                George Jets 1967 Dart 2 Door FABO Gold Member
                1,435
                2033
                Jan 18, 2019
                Farmington MN
                Local Time:
                12:50 PM
                That is a good test Cudafever, going to keep that one in my "Diagnostic Tool Kit".
                Thumbs Up ! . . .
                Oh Wait . . Won't start without the torq converter with ring gear bolted to the crank shaft.
                Good attempt though . . .
                360 external balance converter as example.
                • Thanks! Thanks! x 1
                • Agree Agree x 1
                • George Jets
                  1,435
                  2033
                  Jan 18, 2019
                  Farmington MN
                  Local Time:
                  12:50 PM
                  Cudafever, could still be that the Flex Plate bolts are tight but a tad too long bottomed out in their threaded holes in the converter.
                  This senario the flex plate could still walk on the bolts at the converter producing the knock.
                  Next test, put some flat washers on the 4 flex plate bolts and see if that tightens the flex plate to the converter.
                  Now start it up and test again and see if the noise/knock goes away. If it goes away, tells you wrong length bolts mounting the flex plate to the torque converter.
                  • Like Like x 1
                  • George Jets
                    1,435
                    2033
                    Jan 18, 2019
                    Farmington MN
                    Local Time:
                    12:50 PM
                    Good to take the 4 flex plate bolts out anyhow, like in Post 78 to see if the flex plate holes are starting to Egg Out.
                    All 4 . . .
                  • Cudafever
                    3,436
                    980
                    Sep 27, 2009
                    Local Time:
                    11:50 AM
                    Yeah that was dumb:BangHead: sounded good tho:D my fire wood guy showed up so i typed that real quick and hit send:rolleyes:
                    I think if he get the bolts off and pushes the converter back.
                    a flashlight will tell the story.
                    • Like Like x 1
                    • Agree Agree x 1
                    • Cudafever
                      3,436
                      980
                      Sep 27, 2009
                      Local Time:
                      11:50 AM
                      two long of bolts would have caused the problem from the beginning.
                      • Like Like x 1
