65 CUDA
i am using a 904 transmission from a 78 cordoba in my 65 barracuda and i need advice for what parts i need to use my og shifter handle to use on the cordoba 904 cuz shift cables wont wok on it
Phista: did it come with cables and where would I hook up on the 78 Cordoba transmissionHurst Pro-matic 2 shifter. It fits under the stock floor column and looks stock. Must trim OG shifter mount off tunnel but its easy. Pardon old pic......
I'm using the 360 motor that came with the transmission both are from a 78 Chrysler Cordoba and my 65 Plymouth barracuda fastback is automatic on the floor
i am using the 904 trans/ 360 motor from the cordoba and not the 904/ slant 6 motorUse the converter, pump, input shaft and forward drum from the 360 904 into your 65 trans unless it's a lockup. Might not be. Look at the front of the input shaft see if it has a small smooth extension on it about 3/4" long. If it is a lockup with the shaft extension, go get a non lock 904 for the parts.
