help with 66 valiant rear axle
Early A-Body Discussions
  1. karwash
    karwash Active Member
    33
    1
    Mar 10, 2011
    Seal Beach, Cal
    Local Time:
    9:53 AM
    I have a 66 valiant 100 wagon. The rear end has been whining for quite awhile. Last few days it has been creaking and popping when I stop and start. The noise seems to be coming from the drivers side and it really whines on left curves. I kinda think it's the bearings, but not sure. Anyway, it's time to get my baby fixed.
    Tearing apart the rear axle is beyond my mechanical abilities. I could handle changing out the entire rear axle. Money is a little tight at the moment and I'm trying to avoid the shop expense.
    My question is what cars would have the same rear axle assembly that I could just switch out?
    Any help would be greatly appreciated.
  2. memike
    memike Super Moderator Staff Member FABO Gold Member
    49,043
    9119
    Jan 8, 2006
    on the hill
    Local Time:
    11:53 AM
    My 66 valiant made this kind of noise and I put it up on jack stands and turned and wiggled each tire and found that my outer axle bearing was going out, I pulled the brakes and pulled the axle (no need to open the rear end cover on these 7 1/4"s .... removed axle bearing and replaced it along with a new seal. I did this myself under a tree just had to have the bearing pressed on and then reassembled, I did end up removing the rear end cover and clean but it seamed all my shavings stayed in the outer axle .. This has been 2 years ago and has been doing great, let me go find my pictures on how I did thid and I will post them, I am on my better half's computer at the time
  3. 340duster340
    340duster340 Well-Known Member
    1,150
    48
    Jun 20, 2004
    long island NY
    Local Time:
    5:53 PM
    If you can change out a rear then you have the skills to swap an axle out. That said its probably cheaper to swap the whole rear out yourself than to pay someone to fix the bad axle you have.
  4. memike
    49,043
    9119
    Jan 8, 2006
    on the hill
    Local Time:
    11:53 AM
    This should show you how I did mine, and I do believe if you want to change the rear end out anything up to 73 A body will fit, but remember, you will need U-Bolts if it is a 8 1/4 rear end, yoke,, but finding another 7 1/4 it is possible that it will need this dun as well, I elected to check my problem out and repair it.
    I am not a good tec, But! I am sure one will jump in here and guide you soon..Here is pictures and read what problems I ran into page 19 in my restoration thread here http://www.forabodiesonly.com/mopar/showthread.php?t=41794&page=19 and there is a 66 Valint/dart manual you can down loud here .
  5. RedFish
    RedFish Well-Known Member
    23,052
    2002
    Sep 5, 2007
    Local Time:
    11:53 AM
    The small bolt pattern 7.25 rears are dirt cheap by comparison. The hard part is finding one that isn't just as well worn as the one you have.
    Without doing the research I'm going to say the bearing, etc.. to refurbish the unit are easier to find than the brake drums on it.
    The following is from my experience... A parts yard is going to torch cut U bolts, park brake cables, everything, to remove the axle so the labor in R&R to your car will be quite a task.
    On the other hand, you could drop the unit you have at the spring hangers, properly remove those other attachments, and refurbish it. The 35 bucks for new U bolts could be better spent.
    I did read you comment about your ability but I'm not buying it. If you can read and follow instructions you can do anything.
    If you should find that just replacing one outer bearing will buy some time, that's fine too. It's been done a million times before.
  6. Darter6
    Darter6 Well-Known Member
    3,755
    875
    Jan 16, 2008
    Nevada
    Local Time:
    9:53 AM
    You want to take a drive to Vegas I'll give you the one from my 64 Dart.
  7. karwash
    33
    1
    Mar 10, 2011
    Seal Beach, Cal
    Local Time:
    9:53 AM
    How can I tell if I have a 7.25 rear end or the 8.25????
    Hopefully without pulling the cover off the differencal...
  8. KitCarlson
    KitCarlson Well-Known Member
    2,381
    307
    Jan 17, 2008
    Middle Tennessee
    Local Time:
    11:53 AM
    If it has a cover it is not a 8.25.
    Oops, I was thinking 8.75.
  9. cosgig
    cosgig MoBro Inc. FABO Gold Member
    10,864
    3420
    Jul 20, 2008
    Pinckney, Michigan
    Local Time:
    11:53 AM
    Not true!! 8 1/4" have a cover! If it is the original small bolt pattern it is a 7 1/4", if it has the larger 4.5" bolt pattern it is either a 7 1/4" from 73 and up or an 8 1/4" from 73 and up! Either way it would have to have been swapped in there at some time!
    Measure the bolt pattern and report back! My guess is that it is the original 7 1/4"! Geof
  10. SSVDP
    SSVDP FABO Gold Member FABO Gold Member
    3,993
    3289
    Feb 6, 2009
    Clarksville, Tn
    Local Time:
    12:53 PM
  11. RedFish
    23,052
    2002
    Sep 5, 2007
    Local Time:
    11:53 AM
    There are several ways to tell whether its a 7.25 rear or something else.
    Measure the axle tube diameter.
  12. karwash
    33
    1
    Mar 10, 2011
    Seal Beach, Cal
    Local Time:
    9:53 AM
    OK, Thanks everyone!! I will check it out....
  13. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,449
    1291
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:53 AM
    ................7 1/4 has a 9 bolt cover. 8 1/4 has 10 bolts............kim....
  14. inertia
    inertia Well-Known Member
    3,125
    458
    Feb 4, 2011
    Victoria B.C. Canada
    Local Time:
    9:53 AM
    Wrong... diff cover and "c" clips need removal, to take out axles..
    so he doesn't spend a coupla hrs. tugging...
    Removal and Disassembly
    (1) vehicle to a desirable working height and install jack stands.
    (2) Remove wheel cover and wheel and tire assembly. Remove brake drum.
    Clean all dirt and foreign material from area of housing cover.
    (3) Loosen housing cover and drain lubricant from rear axle and proceed to remove cover.
    (4) Turn differential case to make differential pinion shaft lock screw accessible and remove lock screw and pinion shaft (Fig. 3).
    (5) Push axle shaft toward center of vehicle and remove the “C” locks from recessed groove of axle shaft (Fig. 4).
    (6) Remove axle shaft from housing being careful not to damage the axle shaft bearing which will remain in the rear axle housing.
    (7) Inspect the axle shaft bearing surfaces for signs of brinnelling, spalling or pitting. If any of these conditions are present both the shaft and the bearing should be replaced. The normal bearing contact on the shaft will be a dull gray and may appear lightly dented.
    (8) Remove axle shaft seal from housing bore.
    (9) To remove the axle shaft bearing from axle housing (Fig. 5), use Tool C-4167. Attach Tool C-637 to end of selected remover, using a slide hammer motion, remove axle shaft bearing and inspect and discard if axle shaft or bearing shows any of the conditions. If axle shaft and bearing show no signs of distress, they can be reinstalled along with a new axle shaft seal. Never reuse an axle shaft seal under any circumstances once it has been removed.
    http://www.mopar1.us/axle/#GENERALINFORMATION
    hope it helps
  15. karwash
    33
    1
    Mar 10, 2011
    Seal Beach, Cal
    Local Time:
    9:53 AM
    OK, thanks again everyone!!! I can tell by the backing plate, it is a 7.25 rear end. Now I just have to find a good running replacement.
  16. Darter6
    3,755
    875
    Jan 16, 2008
    Nevada
    Local Time:
    9:53 AM
    Remember If you can't find one in your area, I will gladly give you the one I got.
  17. 66Dvert
    66Dvert speaker kick panels for my dart are good to go! FABO Gold Member
    2,132
    378
    Nov 2, 2008
    Webster , florida
    Local Time:
    12:53 PM
    EH sorry Wrong on a 66 7.25 rear end
    Those instructions Might be right for 8.25's. but for 66 original axles that are 7.25 you don't have any clips. just use a auto store "rental" axle puller after you remove the drums,brake shoes and the 4 bolts holding the axle flange to the axle. (it's easier to have the bearings pressed on and off. but you can do it yourself if you need to. good chisel and a little sweat to go with it can remove the locking spacer. ) I just pay to get mine pressed on for the amount of work involved.
    I just replaced the rear axle bearings in my 7.25 and the axles have NO provision for C clips. I think they made a mistake in those pictures because here's the FSM page showing the 7.25.
  18. RustyPlymouth
    RustyPlymouth Well-Known Member
    425
    6
    May 14, 2012
    new jersey
    Local Time:
    1:53 PM
    when i changed my bearings years ago i took the drum off. took everything else in there off (brakes, backing plate bolts...) and put the drum on backwards and threw a couple lug nuts on there. leave space for the drum to slide on the studs and yank on the drum. mine came out pretty easy. or you could rent the puller.
  19. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    49,167
    15370
    Jun 7, 2010
    Georgia
    Local Time:
    12:53 PM
    Why not get a factory service manual and learn how to do it yourself? It is very simple.
  20. pishta
    pishta I know I'm right....
    14,046
    3726
    Oct 13, 2004
    Tustin, CA
    Local Time:
    9:53 AM
    C clips? No...the bearings are press fit and thats the only thing that keeps the axles in a 7.25. Remove bearing retainer and the axles will slide out with a hard tug. 1 inch wide bearing holding axle in or 1/16" c clip? Ill go with bearing.
  21. karwash
    33
    1
    Mar 10, 2011
    Seal Beach, Cal
    Local Time:
    9:53 AM
    Again, THANKS to everyone for your information and help. Got a line on a ring, pinion and carrier and will buy new bearings all around.
    HAPPY NEW YEAR!!!
  22. fig
    fig Well-Known Member
    194
    20
    Oct 31, 2011
    Jurupa Valley
    Local Time:
    9:53 AM
    I've got a 7 1/4 out of a 66 dart if you are interested. Make you a deal you can't resist!
