1. KB9GIB
    KB9GIB Well-Known Member
    108
    28
    Jul 25, 2014
    Anna illinois
    Local Time:
    5:02 AM
    Can anyone tell me where these go on a new floor pan 72 Demon. Thanks
  2. 4spdragtop
    4spdragtop Well-Known Member
    27,812
    7538
    Aug 28, 2009
    Wasting time here
    Local Time:
    5:02 AM
    Look like brake line brackets?
  3. Dubob
    Dubob Well-Known Member
    1,222
    440
    Oct 28, 2011
    Ohio
    Local Time:
    6:02 AM
    14702185-5091-408A-8B11-B93D1E5E5BDB.jpegView attachment 1715226889View attachment 1715226884 Big bracket is for emergency brake cable. I don’t have an exact position and not sure how accurate it has to be. These are best I’ve got. Hopefully you can see it. I believe if it’s in line with frame rail bracket where cables to differential mount you should be ok.
    • Like Like x 1
    • KB9GIB
      108
      28
      Jul 25, 2014
      Anna illinois
      Local Time:
      5:02 AM
      I can see the e brake bracket it’s hard to see on black maybe someone has a brighter color under side I see a bit better. I do think you for showing me the pictures. KB9GIB
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
      17,125
      5647
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      5:02 AM
      Weld it on last after the E-brake cable has been installed.
      Those other two look like brake-line and fuel-line hangers.
      • Agree Agree x 1
      • charles mill
        charles mill Wildman68 FABO Gold Member
        248
        18
        Jun 20, 2014
        oklahoma
        Local Time:
        5:02 AM
        they r if u have a emissions car most any year clips 4 fuel Vapor to return to tank if non stock no need 4. what year 72 maybe 73 chunk.
