Hemi Bellhousing and Small Block
Manual Transmission & Clutch Discussions
  1. moparspares
    moparspares Well-Known Member
    568
    43
    Aug 10, 2010
    Scarborough, Qld
    Local Time:
    2:23 AM
    Is a 331 Hemi bellhousing the same bolt pattern as a small block Mopar.
  2. sccachallenger
    sccachallenger Well-Known Member
    172
    58
    May 18, 2015
    north carolina
    Local Time:
    3:23 AM
    Early engines had integral bells.
    Later engines will match up to a small block.
  3. 67Dart273
    67Dart273 Well-Known Member
    39,501
    7148
    Oct 14, 2010
    Idaho
    Local Time:
    12:23 AM
    Not all of them. There was only one with the extended bell. And I don't know if they are the same as LA, doubt it. Likely starter mount differences if not more
  4. Jadaharabi
    Jadaharabi FABO Gold Member FABO Gold Member
    5,162
    4892
    Jan 8, 2016
    Peoria, Illinois
    Local Time:
    2:23 AM
    Got a picture?
  5. Dana
    Dana Well-Known Member
    858
    413
    Oct 20, 2011
    Calcutta OH
    Local Time:
    3:23 AM
    I thought the crank on the hemis stick out an extra inch, so a spacer nessesary. Hot heads down in NC has the scoop on all that stuff.
  6. sccachallenger
    172
    58
    May 18, 2015
    north carolina
    Local Time:
    3:23 AM
    I interpreted the question as "bolt up".
    It will "bolt up", now crank offset is different question!
  7. moparspares
    568
    43
    Aug 10, 2010
    Scarborough, Qld
    Local Time:
    2:23 AM
    Here are the pics. I could take it off and try but I have a lot of crap to move to get to it. Thought someone may know.
  8. RAT ROD AL
    RAT ROD AL FABO Gold Member FABO Gold Member
    1,408
    1212
    Jan 18, 2013
    St. James City. FL.
    Local Time:
    3:23 AM
    • Like Like x 1
    • sccachallenger
      172
      58
      May 18, 2015
      north carolina
      Local Time:
      3:23 AM
      If you're running a manual trans with the integral bell the adapter may be as simple as a flat plate of the correct dimension and thickness.
    • 67Dart273
      39,501
      7148
      Oct 14, 2010
      Idaho
      Local Time:
      12:23 AM
      • Like Like x 1
