I'm shopping around for a Hemi hood scoop for my 1968 Valiant and I know which kind I want, but just don't know the "type" of Hemi scoop if there is any. I like the 1968 Hemi hood scoop with the 3 poles holding it up. I see all these Hemi scoops with 2, 3 and even 4 of those poles. Do you add those on there? Or do they come with the scoop when you buy it? Also, I noticed some of those Hemi hood scoops are taller/wider than others. I like the slightly shorter, wider scoop- not the scoop that stands really tall. Not sure of the dimensions of both types of scoops, but I'd thought I would ask you guys. I'm looking at the S602 68 Hemi Scoop. (Dart and Cuda Style) Bolt-On style. 5"H x 34 "W x 24 "Long on this website: http://www.vfnfiberglass.com/Factorystylescoops.htm Is that the one I'm looking for? The slightly shorter, wider one? Do I get the 3 bars with it to hold it up or are those separate? Any help is appreciated, thanks! The scoop in the pictures is the exact one I'm looking for.
Got mine from AAR Fiberglass in Florida. The supports are extra. https://www.aarqualityfiberglass.com/products/scoop-barracudadart-1968-hemi
AAR also...may as well go with four, they come two to a pack. https://www.aarqualityfiberglass.com/products/stantion-post-set
Awesome, I will keep that in mind. Thanks! By the way, the link I posted with that hood scoop is practically the same, but is an $140 difference...why is that?
The difference is; one scoop design will take flight while the other scoop design may not take flight. Be careful what you wish for.
