Hemi hp and tq ?
New Hemi Engine Swaps
  1. 71scamp78
    71scamp78 Well-Known Member
    1,179
    358
    Sep 28, 2014
    terre haute indiana
    Local Time:
    7:28 AM
    Ok I'm debating on building this 5.7 stroked to a 394 with a kit from MMX. It's a 2014 block with stock eagle heads and will be carbureted. Just curious what power output you think it will make. Intake I was thinking of the OCP dual plane. Thinking of building for my GTX because I sold Dart I was going to put it in. Currently I have a 440 in my 69 GTX with a 4 speed dana 60 and 4.10 gears. If not building this was thinking of doing a 440 with some trick flow heads. Here is the cam specs for the Hemi.
  2. 70chall440
    70chall440 Mopar or No Car...
    481
    521
    Jun 9, 2018
    Yelm WA
    Local Time:
    4:28 AM
    I suspect you will get varied responses ranging from "keep it old school" to "upgrade to the G3 Hemi". I fall into the second camp, I would drop a G3 into it in a heartbeat and enjoy the crap out it. Sure, to many a G3 doesn't look as cool as the OS 440, and it is not a super simple or super cheap swap, but what you get back in reliability, drivabilty, and yes durability it worth the effort IMHO.
    • Agree Agree x 1
    • TT5.9mag
      TT5.9mag Two atmospheres are better than one
      2,633
      2754
      May 5, 2016
      So cal
      Local Time:
      4:28 AM
      Depends on what YOU like and what YOU want out of your car. A gen3 hemi stroked, carbureted, with eagle heads should make ~420 to answer your question.
    • 71scamp78
      1,179
      358
      Sep 28, 2014
      terre haute indiana
      Local Time:
      7:28 AM
      420 ? A stock 6.4 makes 485 hp. My cam is way bigger , plus headers. I'm thinking 575 hp
    • TT5.9mag
      2,633
      2754
      May 5, 2016
      So cal
      Local Time:
      4:28 AM
      The carb intakes suck.
    • thesiren74
      thesiren74 Well-Known Member
      2,113
      1788
      Feb 23, 2014
      kenosha,wi
      Local Time:
      6:28 AM
      It's going to make way more than 420hp.
      • Agree Agree x 2
      • thesiren74
        2,113
        1788
        Feb 23, 2014
        kenosha,wi
        Local Time:
        6:28 AM
        I would think 500+ easy
        • Agree Agree x 2
        • thesiren74
          2,113
          1788
          Feb 23, 2014
          kenosha,wi
          Local Time:
          6:28 AM
          Those 5.7l heads flow over 300 cfm stock and what do trickflow non cnc flow?
        • TT5.9mag
          2,633
          2754
          May 5, 2016
          So cal
          Local Time:
          4:28 AM
          Stock 5.7 hemi with long tube headers, still fuel injected. If you guys think there is 150+ hp with a cam swap and going back to a carburetor you need to think again. The stroke will help a little.
        • TT5.9mag
          2,633
          2754
          May 5, 2016
          So cal
          Local Time:
          4:28 AM
          Can you make 575? Sure. But you’ll need a little more than a cam swap
        • thesiren74
          2,113
          1788
          Feb 23, 2014
          kenosha,wi
          Local Time:
          6:28 AM
          Stroke will help a lot! Take advantage of those cylinder heads and cam.
        • TT5.9mag
          2,633
          2754
          May 5, 2016
          So cal
          Local Time:
          4:28 AM
          Cam swap.
        • TT5.9mag
          2,633
          2754
          May 5, 2016
          So cal
          Local Time:
          4:28 AM
          You know what helps “a lot”?
          Turbos.
          • Like Like x 1
          • DionR
            DionR Well-Known Member
            3,000
            785
            May 7, 2008
            Spokane, WA
            Local Time:
            4:28 AM
          • thesiren74
            2,113
            1788
            Feb 23, 2014
            kenosha,wi
            Local Time:
            6:28 AM
            I know it's got the variable intake and tuning but still it's a stock bottom end 5.7l.
            • Agree Agree x 1
            • TT5.9mag
              2,633
              2754
              May 5, 2016
              So cal
              Local Time:
              4:28 AM
              That’s a Richard Holdener test and all he said was it’s a Comp HRT cam. He gave no specs.
            • TT5.9mag
              2,633
              2754
              May 5, 2016
              So cal
              Local Time:
              4:28 AM
              That variable valve intake manifold is surprisingly good.
              • Like Like x 1
              • 71scamp78
                1,179
                358
                Sep 28, 2014
                terre haute indiana
                Local Time:
                7:28 AM
                If a stock 392 makes 485 I'm sure with what I'm building it should make 550 at least. Hell I seen a stroked 360 make over 600 with ported eddy heads. Maybe I should just keep it old school and run a 440 with some good aluminum heads..that big block torque is sweet..maybe a low deck 500 ci stroker idk..
              • TT5.9mag
                2,633
                2754
                May 5, 2016
                So cal
                Local Time:
                4:28 AM
                What do you want? A driver? A race car? 550hp is easily achievable but you should give us a clue what you’re trying to do. The example you gave above, probably does not run on 87 octane and pull 18” of vacuum so let’s call that “not a daily driver”. Then you say “big block torque” which makes me think street car. So what kinda car are we building here?
              • 71scamp78
                1,179
                358
                Sep 28, 2014
                terre haute indiana
                Local Time:
                7:28 AM
                69 gts 4 speed. Street mostly so maybe a good low deck torque monster may be better
              • TT5.9mag
                2,633
                2754
                May 5, 2016
                So cal
                Local Time:
                4:28 AM
                The low deck 451s are great and make great power and torque. But don’t sell the gen3 short, look at the cam swap graph I posted above. It makes over 400lb/ft from 3400 to 5700. That’ll move just about any street car pretty well. And would be a lot of fun with a 4 speed and 4:10s. And I’m sure you’ll save some weight over the big block.
              • 408 swinger
                408 swinger FABO Gold Member FABO Gold Member
                2,883
                3122
                Nov 12, 2010
                Iowa
                Local Time:
                6:28 AM
              • TT5.9mag
                2,633
                2754
                May 5, 2016
                So cal
                Local Time:
                4:28 AM
                That’s a stout gen 3, I looked for the cam specs on the HUG SER2731MHLN
                But couldnt find them. Just to note, it took “fully cnc ported” heads and a cam swap with dual 1000cfm throttle bodies on Holley hp efi to get to 529hp. I’d love to know what compression it is.
              • TT5.9mag
                2,633
                2754
                May 5, 2016
                So cal
                Local Time:
                4:28 AM
              • 408 swinger
                2,883
                3122
                Nov 12, 2010
                Iowa
                Local Time:
                6:28 AM
                I would guess 11ish. Hughes likes cylinder pressure.
              • TT5.9mag
                2,633
                2754
                May 5, 2016
                So cal
                Local Time:
                4:28 AM
                Agree. It does say “runs happily on pump gas”.
