Hemi Pcv
Discussion in 'New Hemi Engine Swaps' started by lefty70, Apr 9, 2018.
  1. lefty70
    lefty70 Member
    6
    0
    Apr 9, 2018
    Ma
    Local Time:
    11:34 AM
    Hello I’m trying to install an adequate pcv system in my Hemi. I am using a Mopar Performance efi manifold with a 4150 flanged throttle body. The pcv port is located directly under the fuel rail with only enough clearance for a tiny Toyota plastic valve. I’d like to plug that hole and make a hole in my plastic valve cover, but I’m not sure if that’ll work correctly. Thoughts?
  2. RealWing
    RealWing Well-Known Member
    643
    128
    Jun 14, 2010
    Ontario
    Local Time:
    11:34 AM
    Suggest post a photo of the area.
    • Agree Agree x 1
    • Abodybomber
      Abodybomber Breaking street machines , since 1983.....:)
      31,523
      9893
      May 21, 2011
      Arroyo grande ca
      Local Time:
      8:34 AM
      Camshaft, idle vacuum..kinda,tells us basic....
    • lefty70
      lefty70 Member
      6
      0
      Apr 9, 2018
      Ma
      Local Time:
      11:34 AM
      I can, my question is could I relocate the pcv. There isn’t enough room for one in the existing hole. There was an install kit available for the intake at one point, no longer available. Imagine the hole directly under the RH fuel rail with about 3/4” clearance. It’s a stock 2003-2008 style crate motor.
    • famous bob
      famous bob mopar misfit
      9,937
      2192
      Aug 14, 2011
      okla
      Local Time:
      10:34 AM
      I don`t see why u couldn`t install it between the rockers for clearance, and add a splash plate.
    • lefty70
      lefty70 Member
      6
      0
      Apr 9, 2018
      Ma
      Local Time:
      11:34 AM
      The red arrow shows the small pcv hole. It directly inline and covered by my Arrington fuel rail.
    • famous bob
      9,937
      2192
      Aug 14, 2011
      okla
      Local Time:
      10:34 AM
      wow, sounds like a well thot out piece. maybe a special pcv for it ??
    • lefty70
      lefty70 Member
      6
      0
      Apr 9, 2018
      Ma
      Local Time:
      11:34 AM
      Yeah they had an install kit. No longer available. I work at a dealer and have looked at every pcv for possible fitment. I’m thinking I could also install a 90 degree elbow then use an inline pcv, maybe?
    • RealWing
      643
      128
      Jun 14, 2010
      Ontario
      Local Time:
      11:34 AM
      A 90 should work fine
      Jim
    • Hellcat Cuda
      Hellcat Cuda Well-Known Member
      496
      27
      Jan 12, 2013
      Northern Calif.
      Local Time:
      8:34 AM
      That manifold was used on the first MP 5.7 crate motor. I had one for the start of my build (evolved to a 6.2 HC). I'm pretty sure it had a 90 degree nippled fitting for an in line valve. I'll find my original paperwork that came with that engine. There's pics, etc.
    • lefty70
      lefty70 Member
      6
      0
      Apr 9, 2018
      Ma
      Local Time:
      11:34 AM
      Awesome!!!
    • Hellcat Cuda
      496
      27
      Jan 12, 2013
      Northern Calif.
      Local Time:
      8:34 AM
      So I could only find about half of my documentation from the MP 5.7 crate I had. I was able to find only one, very clear picture of the manifold that shows that port. However, it the carb version of the manifold but should still help. There is a straight, pressed fit, nippled fitting in that port for a hose with in line PCV valve. I remember a similar, but 90 degree fitting in the one I had.
      I think if it were my manifold, I would tap the hole and screw a 90 degree brass fitting in there and then put an in line PCP in there. Hope this helps.
    • 67Dart273
      67Dart273 Well-Known Member
      37,365
      5115
      Oct 14, 2010
      Idaho
      View My Photos
      Local Time:
      8:34 AM
      There's nowhere in the throttle body for a fitting? No room to tap one?
    • Hellcat Cuda
      496
      27
      Jan 12, 2013
      Northern Calif.
      Local Time:
      8:34 AM
      This port goes into the head area that is exposed to the crankcase. It's not a vacumn port.
    • lefty70
      lefty70 Member
      6
      0
      Apr 9, 2018
      Ma
      Local Time:
      11:34 AM
      That's the same decision I've made. I'm going to take the manifold off to tap it. I can't think of a way to keep debris from not getting into the crankcase without. thanks for looking into this sir.
    • Buschi340
      Buschi340 Well-Known Member
      1,256
      25
      Feb 19, 2005
      Wilhelmshaven, GERMANY
      Local Time:
      4:34 PM
      true. It goes straight down into the pan. I put there a hose to an " Overflow bottle with breather "
    • 1973Barracuda
      1973Barracuda Well-Known Member
      1,403
      1283
      Dec 11, 2009
      Local Time:
      11:34 AM
      Any pics of that ?
