1. pishta
    pishta I know I'm right....
    21,396
    10780
    Oct 13, 2004
    Tustin, CA
    Local Time:
    8:06 PM
    does anyone know if any of these Chinese tabletop style 5-12 speed drill presses use a Jacobs or Morse taper spindle? I see small 3 jaw chucks in M1, M2 and would like to invest in one if they could work. To spin a 1.00" piece
  2. Bill Crowell
    Bill Crowell Well-Known Member
    1,064
    605
    Oct 16, 2007
    Diamond Springs, CA
    Local Time:
    8:06 PM
    How ya doin', Pishta? I have the HF 12-speed floor-standing so-called "production" drill press, which uses the Morse MT-4 taper. My guess is that the tabletop models would use the same taper on their arbors, but if you download the HF instruction manual for the drill press in question, it should tell you the taper of the arbor under "specifications". The arbor on an HF chuck is shorter than some others, in order to let you drive the chuck out with the steel wedge that they supply. I bought an aftermarket small chuck for my drill, which works fine, but the arbor is too long and I'm going to have to cut it off shorter in order to be able to drive it out.
  3. dartfreak75
    dartfreak75 Restore it, Dont part it! FABO Gold Member
    10,829
    8448
    Aug 10, 2011
    Virginia
    Local Time:
    11:06 PM
    I have the table top version i don't know all technical specs but if it helps I can take some pictures and send them to you.
    • Like Like x 1
    • 1WildRT
      1WildRT Active Member
      44
      88
      Aug 13, 2021
      Modesto Ca
      Local Time:
      8:06 PM
      Both... The spindle will accept a Morse taper & the chuck will have a Jacobs taper..
      Separating a Jacobs taper
      Tools to separate a Jacobs taper
    • Steve welder
      Steve welder Well-Known Member
      312
      393
      Jul 24, 2021
      New York
      Local Time:
      11:06 PM
      That’s a drill press
      • Like Like x 1
      • Agree Agree x 1
      • MOPAROFFICIAL
        MOPAROFFICIAL FABO Gold Member FABO Gold Member
        9,433
        8782
        Jun 1, 2016
        Oceanside ca.
        Local Time:
        8:06 PM
        I like my old craftsman , got a adjustable tilting table mount too.
        I use mostly to check springs though.
        • Like Like x 1
        • Steve welder
          312
          393
          Jul 24, 2021
          New York
          Local Time:
          11:06 PM
          They don't build em like that anymore
          Those old Craftsman were great press's and made to last
          • Agree Agree x 1
