Hi flow electric fan
Heating / Cooling / AC
  1. Road/Rage
    Road/Rage Well-Known Member
    93
    22
    Dec 10, 2019
    KY
    Local Time:
    9:35 PM
    I have 65 dart with slant 6. I run a 3 row champion radiator. I want to go with a pusher electric fan that runs 2500cfm or higher and it needs to be low profile. Can someone tell me where to find such a thing with wiring harness etc and how to install instructions or video would be nice>
  2. supertruck
    supertruck Retired Old Fart stock car racer FABO Gold Member
    615
    307
    Feb 14, 2016
    Gloucester, Va
    Local Time:
    9:35 PM
    Most folks on here tend to recommend a puller fan if going electric. Lots of posts on here about the puller vs pusher argument. I'd check Summit, they have about every kind of fan and controller you could want.
  3. Road/Rage
    93
    22
    Dec 10, 2019
    KY
    Local Time:
    9:35 PM
    Ive researched it. Not enough room for puller, It will have to set in front of my radiator. they wiring part is what gets me, I suck at eletrical install!
  4. supertruck
    615
    307
    Feb 14, 2016
    Gloucester, Va
    Local Time:
    9:35 PM
    I'm not great at electrics either. I used the Dakota Digital controller - I have dual pullers. Easy to wire up, even for me. Do a search here and a couple of members have posted really nice wiring diagrams. 318wilrun posted one I believe.
  5. Syleng1
    Syleng1 Karma is real and Life is short... FABO Gold Member
    1,542
    1131
    Jul 5, 2005
    North Franklin, CT
    Local Time:
    9:35 PM
    With the 66 Barracuda I am in same situation. Motor too close to radiator for a pull fan and factory solid fan wont pull enough air flow at idle with a shroud. I tried multiple electric fans and not a lot fit before or after the 3 core radiator.
    There is a fan controller that put a copper tube between the top radiator hose and radiator and has an adjustable Turn on and Turn off switch to control temps. Battery + in and fan + out. Very simple. Summit sells them. Trying to find it for a part number. Eliminates electric issues for people less inclined to try their hand at wiring.
  6. devilchicken
    devilchicken FABO Gold Member FABO Gold Member
    187
    78
    Sep 14, 2014
    central Califorina
    Local Time:
    6:35 PM
    I recommend using spal, the problem is that high CFM airflow and slim design dont go together the more air you want to push you need a comparable sized motor. good luck
  7. famous bob
    famous bob mopar misfit FABO Gold Member
    16,614
    6389
    Aug 14, 2011
    okla
    Local Time:
    8:35 PM
    If u cant cool it w/ a mech fan , u either got a too small fan, too small rad., or under driven pullies . An elec fan wont pull or push as much air as the right mech fan , unless its one of the kick ass late factory deals .
  8. Road/Rage
    93
    22
    Dec 10, 2019
    KY
    Local Time:
    9:35 PM
    It cools nicely. I just hate that ugly metal fan and the noise that goes with it!
  9. famous bob
    16,614
    6389
    Aug 14, 2011
    okla
    Local Time:
    8:35 PM
    HHMM, CANT HEAR MY FAN AT ALL WHEN THE ENGINE IS RUNNING, COURSE , U CANT HEAR ANYTHING ANYWHERE ---------LOL
  10. 70Duster440
    70Duster440 Well-Known Member
    2,703
    401
    Jan 8, 2006
    Washington
    Local Time:
    6:35 PM
    Though less than ideal, I’m forced to run a pusher. SPAL fans are known for actually moving their advertised cfm.
    For me, a 16” (30102047) has worked. Had to modify the hood latch/grille brace for fitment. Not quiet though. A1 Electric Online Catalog -- Spal Cooling Fans and Accessories
    Unless there are some other issues going on it shouldn’t be too tough to cool that S6 with the aluminum rad. Control the air flow. Close any big gaps between the rad and core support (with seals) so air is forced through the core - not allowed to leak around it.
  11. Road/Rage
    93
    22
    Dec 10, 2019
    KY
    Local Time:
    9:35 PM
  12. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    60,883
    32580
    Jun 7, 2010
    Georgia
    Local Time:
    9:35 PM
    Look at the Flex A Lite Black Magic line of fans. They MOVE some air.
    • Thanks! Thanks! x 1
    • Road/Rage
      93
      22
      Dec 10, 2019
      KY
      Local Time:
      9:35 PM
      I already tried one not enough clearance
    • RustyRatRod
      60,883
      32580
      Jun 7, 2010
      Georgia
      Local Time:
      9:35 PM
      Just one? They make many different models.
    • Road/Rage
      93
      22
      Dec 10, 2019
      KY
      Local Time:
      9:35 PM
      the fans when relaxed hit the pulleys the champion radiator takes alot of space
    • RustyRatRod
      60,883
      32580
      Jun 7, 2010
      Georgia
      Local Time:
      9:35 PM
      I thought you wanted a pusher.
      Do you not have room for this?
      Flex-A-Lite Flex-Wave Electric Fans 239
    • Road/Rage
      93
      22
      Dec 10, 2019
      KY
      Local Time:
      9:35 PM
      I do but its took thick. I would have to cut out the hood latch bar support to make it fit! Which I may have to do. That is the one i need though! About 2 3/4 deep is all the room I have with out chopping!
    • BillGrissom
      BillGrissom Well-Known Member
      7,332
      375
      May 10, 2009
      Sacramento
      Local Time:
      6:35 PM
      My 1964 Valiant slant came with a front pusher fan from a M-B and no fan on the water pump. Some gomer wired it direct to IGN on the key switch and melted the switch. The car was overheating slightly on the drive home, even though a 50 F day. That fan just barely fits between the grill struts. I plan to also put one in my 1965 Dart. I have the same fan on my 1985 M-B, but it also has a mechanical clutch fan. I think the electric fan is intended to help the AC condenser and only turns on due to refrigerant temperature at the filter/drier, so might not suffice to cool your slant. If you get one, also grab the vertical mounting bars and cut the wires long after the connector. In general, electric fans move less air than a mechanical one. An exception might be the Taurus 2-speed fan, which hot-rodders like. You also need a 40 A relay to drive the fan, or perhaps a solid-state relay like my 1996 Plymouth minivan uses (~$25, riveted to front bumper for cooling). There is no room to fit a clutch fan in an early-A slant, even the thinnest one (Jaguar). They recessed the water pump into the side of the block to barely fit the engine in (as did GM straight 6, I think).
    • 67 gt
      67 gt A Wog boy who loves his Mopars ! FABO Gold Member
      1,027
      663
      Nov 9, 2011
      Down under
      Local Time:
      11:35 AM
      Check out Maradyne Fans nice units and work well. Can get the push pull versions and low profile versions aswell. MARADYNE High Performance Fans - Products just to add if you have a 45amp alternator it won’t cut it you will need to step it up !
