hosehead
Hey guys, I've been getting into drag racing the last year or so and had a 440 built for my 65 belvedere. I've basically been chasing a light ping at high rpm and it's been a bit challenging to tune. So I did a compression test today and was amazed at my cylinder pressure. 195-205 per cylinder! Anyhow, I know I need a bigger duration cam to deal with some of this cylinder pressure and was looking to go faster anyway. So here is what I'm working with currently:
Stock stroke 440 with .030 over icon pistons
Bullet hydraulic cam(yes, I know this is my problem area). 490/492 235/240@50
Trick flow 240 heads
Street dominator
Holley 850
Rev nator
Stock distributor 15 initial 31 total. (Pings with any more timing)
100 octane helps but want a pump gas motor.
727 with 9.5" ultimate converter flashes to 3800-ish
3.54 Dana.
When choosing a cam, I called bullet and told them what I was doing. DRIVING a car to the track. This has to be a street/strip car. No room for a trailer at present.
So far, I've only run 1/8th mile passes. Runs 7.70-7.80 @ 90 mph.
Icon's website says with my pistons and the 78cc trick flow combustion chamber I should be around 10.9 to 1. I thought I could get away with this combo with the aluminum heads buuuuuuut, maybe not. Lol.
And finally, I was (admittedly) building a mild-ish motor to get my feet wet at the track. After a bunch of passes, I feel good about upping the performance level now.
My budget has me looking at solid, flat tappet cams in the 250-ish duration area. I know I need to release some cylinder pressure to run pump gas. Any help/suggestions are greatly appreciated but go easy on me. Lol. Thanks guys, flame away.....
Street dominator
Holley 850
Rev nator
3.54 Dana.
