Thanks Rusty! That seems in the neighborhood!
I think it's dead nuts on the money. You may find a different recommendation, but hard pressed for a better one, IMO.
That's a good cam and would make some steam, but,
Same duration as the Hyd cam he has now. I think he needs to be in the 305-315 range to get the pressure in some sort of usable range. Also not install it advance, has to go in straight up and likely on a 110 or higher LSA.
Just my guess based on the current cam being 292 duration installed on a 106 CL.
Most in here know I'm not a fan of wide lobe separation cams. I prefer them cut on a tighter LSA. Usually because the sticks are going in lower compression engines. This is the exact opposite situation.
In this case the engine needs reduce compression, so cutting a cam on a 112-114 LSA, installed straight up, will help with a later closing intake valve, reducing compression pressure. It might even help the idle manners as cam is going to be a bunch larger. It's about the ONLY time I'd suggest such a camshaft.
Mopar Perf. "Purple Shaft" Mechanical Camshaft Kit
Tough to find one with all of the aforementioned specs.....lol.
Near Rob's duration specs but have yet to find one on a 112 or 114 lsa.
Anybody will grind you one. Call Schneider and get them to grind that one I recommended on a 112. They'll do it right quick like.
Small block cam.Mopar Perf. "Purple Shaft" Mechanical Camshaft Kit
I gotta thro in here, I run a 292 extreme solid roller, '' about " the same specs as rrr suggested, w/ the hughs 1/6 rockers, its about .620./ .628 on lift , 440/505" wedge. It may not be the perfect cam, but it`s a lot like the old 590 cams, only a little hairier. It is very docile on the street, until u stick ur foot in it, not hard on valve train,. I run alum. raised port heads, and 91 pump gas, 10.3 c.r. , icon dished pistons, cometic .039 thick gaskets, (good quench at about .037-.039 ), loose 3500 convertor, 21 initial , 34 all in at 3400, 44 total cruising. , no pinging. ---- (I have posted this many times), '', IF U NEED MORE OCTANE, GO BUY A CAN OF B 12 CHEMTOOL F.I. CLEANER , $2.99 A CAN, EVERYTHING IN IT IS AN OCTANE BOOSTER, ABOUT 5 DIFF. KINDS! And it works ! I don`t run any at times and have no pinging, but will run it at the track if I ever get around to taking the fish out there. The roller set up is a little more expensive, u can find all the stuff needed on ebay, and save a few $ . Hughs engines has a steel dist drive gear that will work w. a billet cam, I have one in mine. U can make it all work. My first street hemi had 205-210 pounds per cyl. stock, of course it would ratlle w/ ethel in it back than, had to use a little something extra for it too.Small block cam.
Haven't tried 1 or 2 heat ranges ( -23, -22) down on the plugs?Autolite 3924, runs best where timing is now. Not sure about the gasket. Im pretty sure they were out of the fel pro kit. I'm calling the builder on Monday. The block was previously uncut. Only surfaced when engine was rebuilt. Hope to have some more info on Monday after a talk with the builder.
Tell me about ur avatar pic.!!!!
How many miles do you actually drive the car a summer?
Instead of spending money making it run worse, just buy better fuel for it
