[SOLD] Hipo 273 intake
davescuda
Cheshire, CT
Hipo 273 intake 2659284
dirty but in real nice shape
100.00 plus shipping
#2659284 is a marine manifold. Most marine manifolds have a angled carb mounting surface. Just to clarify.
I do not think this one is angled but I will double check.
You might also want to check the bolt hole diameters. Without some more studying, I don't know whether they used the 5/16" bolts like the 65' car engines did.
You might be right. This # doesn't show on my production #'s.
It can be made to work. 8-10 degree slanted or not, a Carter will sit properly with just a slight change in the float height as the fuel will puddle forward, or you can buy a ~$60 wedge (or just plane a wooden one cheap) and correct it. And those bolts angles look post 65.
