1. Slantsix64
    Slantsix64 Well-Known Member
    1,216
    273
    May 11, 2014
    SGV
    Local Time:
    11:44 AM
    I got a Holley 2280, my question is when I give the carburetor gas when the car is off it squirts fuel but stops half way is that normal? Or should it be squirting fuel until the throttle is open fully?
  2. pishta
    pishta I know I'm right....
    14,051
    3729
    Oct 13, 2004
    Tustin, CA
    Local Time:
    9:44 AM
    Holleys will squirt fuel until the piston bottoms. The 4bbls have a spring on the lever that allows the lever to override the pump arm during fast throttle shots so as not to hydro-lock the arm and bend it. The 2280 looks to have the spring forcing the pump down while the arm holds it up, sort of backwards how a 4bbl works. if you get half a shot, unhook the pump link and manually cycle it (push it down) and see if you get more than the arm allows. The arm may be out of adjustment.
  3. Slantsix64
    1,216
    273
    May 11, 2014
    SGV
    Local Time:
    11:44 AM
    So until it hits wot is should be squirting into both barrels
  4. pishta
    14,051
    3729
    Oct 13, 2004
    Tustin, CA
    Local Time:
    9:44 AM
    or until the pump shot is expired. but yeah.
  5. Mattax
    Mattax Just the facts, ma'am FABO Gold Member
    5,612
    3100
    Feb 7, 2013
    Phila. Pa
    Local Time:
    12:44 PM
    Pump shot is to cover the slow reaction of the idle system. This is partly because the idle system works on pressure difference created by manifold vacuum. In many cases, pump shot is done before wide open throttle.
