Cope
Fusing with fire
Hi guys.
I got my 650 DP all apart (almost) and need some help.
My floats are different from the above sticky and im not sure how to remove them and get to the main needle?
The two screws are out can I kust pull the assembly out?
I pulled.lightely and it dont wanna come out.
My carb did not have any check ball under the acell pump?
just these red rubber plugs.
Am i missing parts?
My main jets are 67 and primarys are 73.
dose this sound factory or even close to right?
My secondary meetering block has no power valve, is this normal?
(Ive always been a webber guy (ducking) and this is my firts holley.)
My secondary pump dischare nozzles are 28 dose sound about right?
Carb is going on a weiand action pluss + on a 318 untill my 360 is ready.
Thanks for the time and advice.
Am i missing parts?
