Holley 4150 way to high idle.
Fuel and Air Systems
  1. Cope
    Cope Fusing with fire
    2,860
    2619
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    3:26 PM
    Hi folks i need some help with my carb.
    Car is a 1971 dart 318.
    I just removed the dizzy to fab new kickdown linkage (not hooked up) and now I have an insane high idle, like 2,000 Rpm high (no tach).
    Curb idle screw is not even touching the cam.
    no matter how much timing I pull out I cant get a good idle?
    Timing is around 8 BDTC but to even get where it dosnet sound like my engine is gonna blow Im at @ 10ADTC.
    I have sprayed the carb with eletric parts cleaner and found no air leaks.
    Both main and secondary butterflys are closed. I cant understand how with all the blades FULLY closed it can even pull that much air?
    I just rebuilt the carb and it was working fine before I pulled the kickdown linkage and Dizzy.
    It dose look like a lot of fuel is dumping out of the primary discarge nozzles but I never looked before so I dont have a base line to truly judge off.
    Thanks for any and all ideas.
  2. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
    15,454
    4506
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    3:26 PM
    -Assuming you are correct when you say all butterflys are closed: Did the pcv line or brake booster line get accidentlly dislocated or cracked?
    -Its also possible that the PV is ruptured.
    -Curb idle screw and cam dont belong in the same sentence for 4150s
    - with closed blades the nozzles should absolutly NOT be flowing
  3. rmchrgr
    rmchrgr Skate And Destroy
    3,419
    101
    Apr 15, 2008
    Stamford, CT
    Local Time:
    4:26 PM
    I would look there. Clearly something was disturbed or not put together correctly. Re-trace your steps, it's probably something simple. Maybe you reversed a gasket uncovering a hole inside the carb or something.
    Kind of sounds like a vacuum leak. Cover the carb while its running, see what happens.
  4. TrailBeast
    TrailBeast Slightly Twisted Member
    19,520
    5966
    Mar 11, 2011
    Arizona
    Local Time:
    1:26 PM
    I'd bet on this.
    Totally sounds like a vacuum leak.
  5. Cope
    2,860
    2619
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    3:26 PM
    Dam I feal stoupid..
    main butterflies were not fully closed....
    My new throttle linkage was holding them open almost a 1/4 inch...
    Gonna reset and see what happens...
    Face palm..
  6. BIG-B-Barracuda
    BIG-B-Barracuda Well-Known Member
    1,133
    93
    Dec 25, 2011
    CALIFORNIA
    Local Time:
    3:26 PM
    I had the same issue, because I had replaced the base and gaskets of the carburetor/intake with thicker versions so because it was taller the throttle cable was throwing the idle off. Stupid mistake that I overlooked. Thank guys for the clear insight always turns out to be some thing small and simple.
