[SOLD] Holley 4779 750 Double Pumper - Used
Rocket
U.S.A.
I have a lightly used Holley 750 with mechanical secondaries, manual choke and 4 corner idle adjustment. This carb was used for some dyno sessions. It is set up with 72 jets in the front & 78 in the rear. Power valve is 4.5 in the front and the rear metering block is plugged. One minor modification was the front throttle blades were drilled for idle air. They were removed, the holes welded shut and reinstalled.
Carb is in excellent shape with little use.
Price is $400 plus shipping.
PM me with any questions.
