Holley Choke Plate Assembly
ConValiant64
Brigantine, NJ
Does anyone have a choke plate assembly for a Holley 650 double pumper with a manual choke (model #4177)? I bought a rebuilt from a FABO member and didn't take notice upon arrival that this piece was missing. I have the actuating rod, but will require the plate and all parts necessary to secure it to the air horn. Thanks.
I pulled the choke off my 750, should be the same. I'll ck aft work today.
I believe I have a complete electric choke assembly also, if you want to go that route
Let's keep both options on the table.
Turns out I have two complete electric assembly's. One has a black choke housing and one has a polished choke housing. There both new take offs. The black is off a proform carb which uses a Holley style main body and the polished one is from a Holley. Both choke plates are the same shape, so either should work. If you just want a plate, l can pull one off an old carb. Let me know what 'll you need and I'll get it out.
PM
