briankaplan
greenduster
Well, I just got in from the garage. Put the Holley carb on the
Duster. Also used the Holley 34-150 fuel line with it.
What a pain in the a**. That thing leaked a stuck pig.
Thought I had a bad float bowl. But sent the carb out to
Bigs performance carbs of Altona, Wi. They would of said
something. The flairs of the line were just terrible. I tried
to tighten them the way I normally would. It justed pi**ed out.
Had to take them to work today and keep working them tight and
loose about a dozen times. Fianlly got them straight.
Got it home and put it on. NO LEAKES. Just redicules on what I
had to do to stop the leaks. Has anyone else had that problem?
I thought been both Holley parts. It should work better.
As far as the carb. I couldn't be happier. I would recomend
Bigs Performance Carbs to everyone. That thing fired right off
and ran great.
and ran great.
