[FOR SALE] Holley Sniper Retrofit Fuel Pump
Just Send It
There goes the neighborhood!
Oregon
Holley Sniper retrofit in-tank fuel pump. This is a return-stye. It is 9" from the top to the bottom. It was cut to fit into a 71'-76' OEM fuel tank. The pump supports up to 900hp carbureted and 700hp EFI. It's very quiet. Only has about 50 road miles on it. It's practically new. I had to switch over to a larger Magnafuel pump when I switched to E85, so no need for this.
Comes with the 8AN fittings
Holley part #19-350
https://www.holley.com/products/fue...etrofit_fuel_module/return_style/parts/19-350
$250 shipped within the lower 48. Venmo and PayPal F&F okay.
Trades:
I'm in the market for a nice set of Small Block solid roller lifters (no pushrod oiling). If you're interested in this pump and have a set you're willing to part with, I'd trade the pump + cash.
I looked at the product specs, didn't see the size listed for the hole needed to be punched-out/cut in the tank, ?
Thx, Jim K6
