Holley Street Avenger 670cfm to big for 318cui?
Small Block Mopar Engine
  1. KingGermanFool
    KingGermanFool Member
    7
    21
    Jan 19, 2021
    Bavaria, Germany
    Local Time:
    12:20 AM
    Hi,
    i have bought some new parts for my stock 1969 Plymouth Barracuda, 318 small block with 4 speed manual.
    I read the following article:
    https://www.streetmusclemag.com/news/common-upgrades-for-an-la318-in-a-1971-dodge-dart-swinger/
    Therefore, I decided to also buy the 670cfm Holley Street Avenger.
    After searching some more information I am now unsure about the decision.
    Is this carburetor too big for my 318?
    I have bought the carburetor at Summit. Should I send it back and get a smaller one?
    Which one would you recommend for my setup?
    This is the list of parts what I have bought:
    Carburetor:
    Holley 0-81670 - Holley Street Avenger Carburetor
    (670 cfm, Square Bore, 4-Barrel, Vacuum, Manual Choke, Dual Inlet, Silver, Each)
    Intake Manifold:
    Weiand Intake Manifold 8022WND Stealth Aluminum
    Valve Covers:
    Mopar Performance P5007613AB Valve Covers
    Air Cleaner:
    Holley 120-153 - Holley Vintage Series Air Cleaner
    Ignigtion:
    MSD Ignition 6425 - MSD Digital 6AL Ignition Controller
    MSD Ignition 8203 - MSD Blaster 2 Ignition Coil
    MSD Ignition 85551 - MSD Pro-Billet Distributor
    Thank You
    Greetings from Germany
  2. Lelo Dart
    Lelo Dart * FABO Gold Member
    1,483
    435
    Oct 10, 2012
    Knob Noster MO.
    Local Time:
    5:20 PM
    No, it should be fine. My 318 really liked the 570 Holley but it will run fine with the 670. I now run the 670 on a 5.9 which runs well but tried an 870 and it ran just as fast but was less responsive on the street and was fouling plugs.
  3. 66fs
    66fs FABO Gold Member FABO Gold Member
    5,590
    2157
    Sep 9, 2009
    Greenwood, South Carolina
    Local Time:
    6:20 PM
    I've run a 750 cfm TQ on a 273, As long as the fuel mixture is good, I would not worry about it. I see you have a 4 speed that should help.
  4. rumblefish360
    rumblefish360 So close, yet so far away FABO Gold Member
    40,660
    12212
    Jun 21, 2005
    New York, on a Island
    Local Time:
    6:20 PM
    Keep it and run it. Once you spend a little time tuning it so it doesn’t run rich or lean, it’ll be just fine.
  5. mopowers
    mopowers Well-Known Member
    5,488
    2515
    Feb 15, 2006
    West Sacramento, CA
    Local Time:
    3:20 PM
    An interesting note about those 670 SA's - They have the same venturi and throttle bore diameters as a regular old 3310, which Holley rates at 750 cfm. Not sure how they come up with these ratings.
    • Like Like x 1
    • KingGermanFool
      7
      21
      Jan 19, 2021
      Bavaria, Germany
      Local Time:
      12:20 AM
      Thank you guys for your feedback!
      I'll keep the 670cfm.
      Now I have another question wich may is not worth an extra thread.
      I have bought a "Weiand Intake Manifold 8022WND Stealth Aluminum".
      Weiand 8022WND Weiand Stealth™ Intake - Chrysler Small Block V8
      In the desciripion it is stated to fit for 318 - late style.
      What does that mean? Will it fit my 1969? Or do I need another intake manifold?
    • 318willrun
      318willrun Utube channel 318willrun
      16,908
      18952
      Sep 13, 2013
      I'm here
      Local Time:
      5:20 PM
      Carb will work just fine. Intake will work, I think they mean LA style.
    • Mattax
      Mattax Just the facts, ma'am FABO Gold Member
      11,828
      7581
      Feb 7, 2013
      Phila. Pa
      Local Time:
      6:20 PM
      The area you may have difficulty with is the carb's circuit calibration.
      If so, as long as you are willing to spend the time and energy, it can be recalibrated with some home shop work.
      In my opinion potentially the MSD 6AL and distributor are going to be the bigger headaches.
      Some of that is luck of the draw (quality)
      The rest depends on what has been done to the engine.
      If its a stock engine the issues will be:
      The carb is likely to be rich at idle and take some effort to tune for good low speed.
      Its going to be rich because it will have strong manifold vacuum. (Low MAP) with a stock cam etc.
      The distributor issue will mostly be the advance curve. Chrysler engines like the two stage advance and the MSD distributors advances are really not good for creating an advance curve shaped like that.
      • Agree Agree x 2
      • mopowers
        5,488
        2515
        Feb 15, 2006
        West Sacramento, CA
        Local Time:
        3:20 PM
        Just curious - if not the 6AL, what ignition do you recommend?
      • Mattax
        11,828
        7581
        Feb 7, 2013
        Phila. Pa
        Local Time:
        6:20 PM
        Assuming its a stock '69 2 bbl 318 ?
        Going to a four barrel, probably a Pertronix in factory single point distributor set up with a curve similar to '67 273 4 bbl.
        But if the 6AL works, I'd use that with a single point distributor set up with a curve similar to '67 273 4 bbl.
        I think the difference between the kettering and the multispark ignition in terms of producing a good burn are going to be too small to notice here. So then its just a matter of reliability. And it seems that nothing aftermarket has been really bulletproof in recent years. :(
      • Ricks70Duster340
        Ricks70Duster340 Child of the King, widower FABO Gold Member
        171
        74
        Feb 8, 2021
        Sisterdale, TX
        Local Time:
        5:20 PM
        The "early style" 318 was the poly. Their choice of words is poor. They should have said that it fits all "LA" engines. They mentioned the 340 & 360, which were both "LA". LA simply means "lightweight A".
        • Like Like x 1
        • sireland67
          sireland67 FABO Gold Member FABO Gold Member
          9,580
          3835
          Oct 27, 2010
          WV
          Local Time:
          6:20 PM
          I think you will be fine, the street avengers tend to run alot leaner than other similar sized carbs.
        • Bewy
          Bewy Well-Known Member
          495
          271
          Jan 1, 2021
          Australia
          Local Time:
          8:20 AM
          I will disagree with the other opinions & suggest you swap the Holley for an Edel AVS2 carb.
          My reasons?
          - main reason is that although both carbs have similar cfm ratings, the Edel has smaller primaries [ secondaries are larger to give the total of 650 cfm]. Smaller primaries, all else being equal, give better response/feel. With the H carb, all four bores are the same size. Plus, the Edel has annular boosters in the primaries. The combination of the smaller pri bores AND the ann boosters will give better throttle response on the primaries, where most driving is done. Fuel economy should also be better.
          - the engine is stock. So a carb that 'livens up' an otherwise stock, low power engine will make you feel like the expense of a new carb was worth it.........
          • Agree Agree x 1
          • Ricks70Duster340
            171
            74
            Feb 8, 2021
            Sisterdale, TX
            Local Time:
            5:20 PM
            I just replaced my Street Avenger 670 with an AVS2 650. Yes, the low speed throttle response is a little better, but not significant. Fuel economy should be better because unlike the Holley, the AVS2 only opens the secondaries at near WOT. Either one should be fine. The AVS2 comes with a 3/8" fuel inlet nipple, so I had to take the nipple off of my original AVS and put it onto the new carb because my stock fuel line is 5/16". Basic tuning of the new carb was simple. Bought the jet kit but don't need it for my basically stock engine.
          • racerdan80
            racerdan80 Well-Known Member
            356
            79
            Feb 14, 2010
            OKC, OK
            Local Time:
            5:20 PM
            Keep the 670 and tune it. I run that on my 68 318 with the stock cam and headers. Ran real good after just tuning to what the motor wanted
          • 318willrun
            16,908
            18952
            Sep 13, 2013
            I'm here
            Local Time:
            5:20 PM
            Personally, I prefer 1200 cfms on my 318...... hooked direct, 1 to 1 :)
            :poke:
            :poke:
          • rumblefish360
            40,660
            12212
            Jun 21, 2005
            Local Time:
            6:20 PM
            Note, that intake has no provisions to mount a coil.
            • Like Like x 1
