Holley Swap Pan Issue
New Hemi Engine Swaps
  1. jlmotorsports
    jlmotorsports Member
    6
    1
    Mar 22, 2021
    South Haven, MN
    Local Time:
    10:41 AM
    Trying to put a holley swap pan onto my 08 5.7 for my 70 dart swap. Ran into an issue when putting in the oil pickup tube, when the pickup is in the pump and located on the stud near the middle of the engine, the hole where the bracket mounts at the oil pump does not line up. It seems to be clocked incorrectly as everything else seems to line up properly, except that hole, has anyone else.had this issue? sent email to holley but couldn't get anyone on the phone yet, thought I'd try here.
  2. MOPAROFFICIAL
    MOPAROFFICIAL FABO Gold Member FABO Gold Member
    9,946
    9256
    Jun 1, 2016
    Oceanside ca.
    Local Time:
    8:41 AM
    Never heard of a holley swap pan...Damn, where the fk have I been!lol
    Remove and relocate the tab on the pickup tube if need be.
  3. Stephen Mulkey
    Stephen Mulkey FABO Gold Member FABO Gold Member
    852
    618
    Nov 29, 2016
    California
    Local Time:
    8:41 AM
    Is that pan for a LA or a Magnum engine?
    I did a quick Search and all I found was GM LS kits.
    I could have missed something.
  4. Professor Fate
    Professor Fate Push the button, Max...
    2,680
    3745
    Jan 13, 2020
    Wisconsin
    Local Time:
    10:41 AM
    An '08 5.7 hemi, he said. New Hemi Forum.
    • Agree Agree x 2
    • Stephen Mulkey
      852
      618
      Nov 29, 2016
      California
      Local Time:
      8:41 AM
      Thanks, I just found it deep in the Holley site.
      Sorry, carry on :)
    • jlmotorsports
      6
      1
      Mar 22, 2021
      South Haven, MN
      Local Time:
      10:41 AM
      Yeah holley part number 302-60 or 302-61 for vvt engines, seems like a nice piece except for this one issue, if nobody else has had an issue I'll just chop it and reweld it.
      • Like Like x 1
      • jlmotorsports
        6
        1
        Mar 22, 2021
        South Haven, MN
        Local Time:
        10:41 AM
        here are photos, the end bracket fits nice onto the main stud, and the tube runs nicely along the windage tray, but when all is said and done the hold at pump is about a full diameter off, think I will chop/rotate/fix it, but wonder if this is an isolated issue, issue with all pans, or something weird with my engine that it's not right.
      • Professor Fate
        2,680
        3745
        Jan 13, 2020
        Wisconsin
        Local Time:
        10:41 AM
        Y'know, I'd let Holley know and show them the pics- and then go ahead and fix it. They'll either make it right with you, or claim that they've never had any complaints before... but it's a new product and early enough in the production run that they may actually appreciate a heads up about it.
        • Like Like x 1
        • 408 swinger
          408 swinger FABO Gold Member FABO Gold Member
          2,643
          2824
          Nov 12, 2010
          Iowa
          Local Time:
          10:41 AM
          Make sure they sent you the right tube. I haven't used Holley stuff yet. But, I have plenty of experience with the Milodon stuff. That is the exact difference between VVT(Eagle), and earlier 08 down.
          • Agree Agree x 2
          • Like Like x 1
          • Professor Fate
            2,680
            3745
            Jan 13, 2020
            Wisconsin
            Local Time:
            10:41 AM
            Good to know! :thumbsup:
            Gentlemen, we have an answer!
            • Thanks! Thanks! x 1
            • 408 swinger
              2,643
              2824
              Nov 12, 2010
              Iowa
              Local Time:
              10:41 AM
              Didn't want to be long winded. I ran into this very issue between 09 up Eagle and 08 down early engines with the Milodon stuff. Doing a quick switch in the son's Scamp. VVT for an early. Had an extra oil pan, not the tube. Thought, well, how different can it be. Well, there you have it. It's so f@×%$in close! WTF?!!! LOL.
              • Like Like x 1
              • Agree Agree x 1
              • jlmotorsports
                6
                1
                Mar 22, 2021
                South Haven, MN
                Local Time:
                10:41 AM
                I will definitely double check the boxes and contact holley tomorrow, but is there a chance I actually have a vvt engine and just don't know it? it's from a 08 truck and I don't think the engine was ever replaced so just assumed non eagle non vvt, am I wrong? what's the easiest way to tell for sure? engine is still 90 percent together as pulled, only intake is off. thanks for the help so far, we will see what I can find out tomorrow when I get back out to the shop
              • 408 swinger
                2,643
                2824
                Nov 12, 2010
                Iowa
                Local Time:
                10:41 AM
                On the VVT, there will be a solenoid under the intake, directly behind the "birdhouse"/water pump area.
              • jlmotorsports
                6
                1
                Mar 22, 2021
                South Haven, MN
                Local Time:
                10:41 AM
                ok, no vvt solenoid, maybe I got the tube for the vvt engine by mistake, will be calling holley today and see what they say, thanks again for everyone's help
              • Ron Boyd
                Ron Boyd Member
                14
                12
                Sep 13, 2021
                Colorado
                Local Time:
                9:41 AM
                I'm considering this pan for my aluminum 6.1 block with a very leaky milodon pan. Other than the misclocked pickup attachment, has it worked out well? Is it leaky? Does it seem like they got the mating surface pretty flat?
              • jlmotorsports
                6
                1
                Mar 22, 2021
                South Haven, MN
                Local Time:
                10:41 AM
                it does seem very well built, the flange is thick and seems very flat. I haven't got the motor ready to run yet so haven't filled it with oil yet, but came with orings installed, and a decent set of instructions for truck motor vs car motor setup. I would recommend it so far, just haven't had a chance to put it through its paces yet on a running engine, but hopefully soon!
              • 68cuda408
                68cuda408 FABO Gold Member FABO Gold Member
                560
                224
                Jun 4, 2013
                11967 NY
                Local Time:
                11:41 AM
                I swapped my non vvt milodon stuff for the holley stuff (I wanted the drop in windage tray and o-ring gasket) . Found out the hard way after pulling the milodon (again) without unbolting anything but the pan , that the holley wouldn't fit back in without raising the engine and lowering the hdk k-frame. I would guess it would be tighter with a stock k. Then found out the pan doesn't seat with studded mains. The rear bolt boss casting hits the stud nuts and required grinding the inside of the pan. 408 swinger called it on the vvt pick up tube. Just make sure you have the correct pump too since that's what the tube bolts to.
                • Ron Boyd
                  Ron Boyd Member
                  14
                  12
                  Sep 13, 2021
                  Colorado
                  Local Time:
                  9:41 AM
                  Thanks for the replies. I'm running a Bouchillon 7.0 liter gen 3 crate with an aluminum block. As such, I have no idea on the internals since they can't provide them and Arrow racing(who built the engine for Bouchillon) is out of business now. You wouldn't happen to be able to measure the vertical height of the pan at the first bolt after the front bevel, would you? I'm running an aftermarket K and all that's under the pan is the steering rack, but there's not a lot of clearance above it.
                  Thank you both for the info.
                • 68cuda408
                  560
                  224
                  Jun 4, 2013
                  11967 NY
                  Local Time:
                  11:41 AM
                  Im Not sure what measurement you mean, but both pans fit the hdk kframe, Reilly should be the same. It's the pickup tube that prevented the holley pan from slipping in. Holley has a deeper "drop" before the rearward bend preventing the thicker pan from sliding up and In. Btw prefix racing is supplying arrow stuff .
                • Ron Boyd
                  Ron Boyd Member
                  14
                  12
                  Sep 13, 2021
                  Colorado
                  Local Time:
                  9:41 AM
                  I meant: The front of the pan has a bevel on both sides. Once the pan reaches full width after the bevel, there is a bolt on both sides(the first of many really). Those first bolts are directly above my steering rack. I was just wondering the height of the pan at that exact point.
                  I bought all the stuff on my car quite a few years ago. I don't have a lot of hope that Prefix will have records of my build, but I'll certainly call and ask them.
                  It takes a long damned time to build a car when you're just doing it on weekends. I've gotten a couple of thousand miles on the car and have to pull the TKO to fix a leak from the top and figured I might as well do some other things while I've got it up and apart.
                • 68cuda408
                  560
                  224
                  Jun 4, 2013
                  11967 NY
                  Local Time:
                  11:41 AM
                  20210913_193117.jpg 20210913_193117.jpg here you go,from the pan rail,looks to be 4 1/8". I had just put the car back in the garage from yesterday (show and track time)so it was on the lift. I also measured the pan sump to rack tube. 20210913_193123.jpg
                  • Like Like x 1
                  • 68cuda408
                    560
                    224
                    Jun 4, 2013
                    11967 NY
                    Local Time:
                    11:41 AM
                    I forgot I have just about 3" to the top of the rack tube., assuming you have a 1 1/8" diameter tube
                  • Ron Boyd
                    Ron Boyd Member
                    14
                    12
                    Sep 13, 2021
                    Colorado
                    Local Time:
                    9:41 AM
                    Thank you so much! I have a 2" diameter tube on my rack(flaming river power rack) and about 4 5/8 to the bottom of the tube. Do I see right that the tube-to-pan measurement looks to be 5/8"? I only have about 5/32" between my rack and pan now, so maybe that'll give me the clearance I need. Your rack looks to be slightly more aft than mine. It's really close whether or not it will clear.
                  • Ron Boyd
                    Ron Boyd Member
                    14
                    12
                    Sep 13, 2021
                    Colorado
                    Local Time:
                    9:41 AM
                    I have a pan in hand now...it looks like it will just barely fit. Excited to get that in there.
                    • Like Like x 2
                    • Ron Boyd
                      Ron Boyd Member
                      14
                      12
                      Sep 13, 2021
                      Colorado
                      Local Time:
                      9:41 AM
                      Update: If you're using rear main studs instead of bolts, you may need to clearance the pan at the middle two bolts in the back. I had to do so and the pan now fits fine. The clearance area for me was around 1/8" horizontal vs 3/16" vertical. I had no problem with the bolt holes being in the wrong place for the pickup.
                      Even with my larger diameter rack, it seems to fit fine at this point. My transmission is out, so the back of the engine is hanging lower, but I pushed the back up as hard as I could and I still cleared the rack.
                      • Agree Agree x 1
