Hood Clearance to CARB
bacaruda
WV
B block, Stage VI, earlier RB M1 for T-Quad.
FIT? Also have Holley SD, I know fits, makes more HP, but M1 looks better.
Jim.
If you have the dimensions of the carburetor in question. You can then place modeling clay on top of your air cleaner. . Close the hood gently then raise it. You should be able to accurately measure the over all clearance available based on the compressed height of the clay. I have no personal knowledge of your proposed setup.
Yote
That probably puts the carb in the same location as an rb right? Going to be tight. I have a b m1 intake, I haven't tried clay on the air cleaner so I can't say how much room i have but it's definitely close.
