Hood Pops up at the cowl
Mopar Body and Trim
  1. Kent mosby
    Kent mosby FABO Gold Member FABO Gold Member
    614
    578
    Aug 24, 2018
    Idaho
    Local Time:
    6:41 AM
    I had the hood off for about a year. When I replaced it, I put on new rubber pads. Now when I close it the rear of the hood at the cowl pops up. I have to manually push it down for it so sit flush. I removed one of the rubber stops. What adjustment is needed to fix this. I am certain that it is in the same place on the bolt holes. any help appreciated. After pushing it down at the cowl, it stays down.
  2. Murray
    Murray FABO Gold Member FABO Gold Member
    2,303
    1652
    Apr 19, 2010
    San Jose, California
    Local Time:
    6:41 AM
    New side hood rubbers are probably not allowing hood to "settle in" to position. Old rubbers are now "V" notched over time. Some adjustment/modification may be needed.
    • Thanks! Thanks! x 1
    • lilfontleroy
      lilfontleroy annoyinglilLeroy FABO Gold Member
      3,984
      3360
      Nov 20, 2017
      Intercourse
      Local Time:
      8:41 AM
      you changed things so things are going to change, just because the hood is set in the bolt holes exactly as before doesn't mean it's right now, some additional adjustment may be needed
      • RustyRatRod
        RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
        71,748
        46935
        Jun 7, 2010
        Georgia
        Local Time:
        9:41 AM
        That was so clear, it sounded like a politician.
        • Like Like x 4
        • lilfontleroy
          3,984
          3360
          Nov 20, 2017
          Intercourse
          Local Time:
          8:41 AM
          :p:lol::p
        • Projectile Dart
          Projectile Dart Well-Known Member
          185
          117
          Jun 30, 2017
          Long Beach, CA
          Local Time:
          6:41 AM
          Sounds like you have the hood set to the previous bolt holes position with *old* rubber stops... Now you need to find new bolt hole positions with new rubber stops
          • Kent mosby
            614
            578
            Aug 24, 2018
            Idaho
            Local Time:
            6:41 AM
            My brain says to try with the rear bolts lower and the front bolts higher. Sound right?
            • Agree Agree x 1
            • Darticon
              Darticon Well-Known Member
              154
              96
              Aug 29, 2014
              Missoula, MT
              Local Time:
              7:41 AM
              I had this happen with mine simply because I did not tighten the bolts down enough.
              • Agree Agree x 2
              • Kendog 170
                Kendog 170 Let the boy go !
                2,139
                1475
                Mar 10, 2016
                Tewksbury Ma.
                Local Time:
                9:41 AM
                If you open the hood and push up on it the back bolts that are slipping will let it slip in the direction you want. Then make sure you tighthen the bolts. Don't strip them. Then slowly close the hood but watch the back and make sure it didn't go down too far. You don't want the hood lower than the cowl or it will bind. I'll have to assume your hood to fender lines are good. That's how I adjust mine by myself. If that doesn't help you'll have to loosen all four hood bolts some and have someone hold hood up while you pull the back of the hood down. Let me know how you make out.
                Good Luck.
                • Agree Agree x 2
                • mcodecuda
                  mcodecuda Senior Member
                  704
                  286
                  Sep 17, 2007
                  Sherrills Ford NC
                  Local Time:
                  9:41 AM
                  My hood on my Barracuda sat like that for years after I changed the motor. I sold the car and just before the transporter picked it up I made this very adjustment. It sat perfectly after that making me wonder why I didn’t do it years before that.
                  • Like Like x 2
                  • flingdingo
                    flingdingo Well-Known Member
                    332
                    263
                    Apr 26, 2017
                    El Lay
                    Local Time:
                    6:41 AM
                    How long was the hood off?
                    I had a car sit for about a year with the hood off and the hinges "up" that did the same as yours when I put the hood back on. I lubed all the pivot points of the hinges and it solved the problem. I don't know if the hinges got a little rusty or just took a set from sitting with no weight on them.
