Hotchkis Front sway bar and caliper interference
Suspension, Steering and Chassis
  1. my68barracuda
    my68barracuda Well-Known Member
    662
    272
    Dec 6, 2009
    Indianapolis IN
    Local Time:
    8:48 PM
    Hello
    ordered a Hotchkis 22385F front sway bar for the 68 Barracuda
    I have the 73 and up front mounted brake calipers.
    I have not received / installed it yet, but looking at the instructions,
    since the sway bar mounting tabs weld to the upper control arm
    inside of the front strut rods, it does not appear that the sway bar link could
    interfere with the calipers,
    is that correct?
  2. GMachineDartGT
    GMachineDartGT Senior Member
    1,492
    179
    May 9, 2006
    203 West Hills Road
    Local Time:
    8:48 PM
    It wont. You can always rear mount the calipers if necessary.
    • Agree Agree x 1
    • Valkman
      Valkman Well-Known Member
      809
      234
      Sep 13, 2012
      NC
      Local Time:
      8:48 PM
      Yeah all you have to do is swap the spindles but you'll need longer brake lines as well.
    • my68barracuda
      662
      272
      Dec 6, 2009
      Indianapolis IN
      Local Time:
      8:48 PM
      I was looking at changing to rear mounted calipers,
      found the '80 F body calipers hard to find,,,
      AZ said they are not available
      NAPA said they can do a special order out of Philly (Cardon)
      That got me thinking of staying with the front mounted calipers
      and worrying over interference with the sway bar
    • 72Dart6pack
      72Dart6pack Harder Better Faster Stronger.
      2,977
      2025
      Feb 1, 2016
      Roseville Michigan
      Local Time:
      8:48 PM
      Use stock calipers facing rearward and use 1969 Camaro front brake hose. Problem solved.
    • my68barracuda
      662
      272
      Dec 6, 2009
      Indianapolis IN
      Local Time:
      8:48 PM
      When I hand held the regular calipers to duplicate swapping sides and moving to the rear it appeared to me that would put the brake line fitting higher than the bleeder valve,,,
      And the 69 Camero brake hose that I looked at on line did not have a banjo fitting, it looked like it screwed directly into the caliper, is that the correct one?
    • 72bluNblu
      72bluNblu FABO Gold Member FABO Gold Member
      9,364
      3436
      Nov 28, 2008
      NorCal
      Local Time:
      5:48 PM
      With that Hotchkis sway bar and where the end links mount you shouldn’t have any issues mounting the calipers to the front.
      The only caliper to sway bar clearance issue is running the 68-72 stock style sway bar with the stock 68-72 end link mounting locations with front mounted 73+ calipers. The Hotchkis end link mounts are not in the stock location for the 68-72 cars.
      • Agree Agree x 1
      • autoxcuda
        autoxcuda Well-Known Member
        6,230
        533
        Apr 6, 2007
        Local Time:
        5:48 PM
        If he’s running Hotchkis UCA’s they won’t rear mount with pin calipers. Been there.
        Would need to check in slider 73-76 Calipers. IMHO, doubtful.
        The Hotchkis UCA take a wide swing at the rear.
      • autoxcuda
        6,230
        533
        Apr 6, 2007
        Local Time:
        5:48 PM
        The Hotchkis front sway bar mount mounts to the lower control arm.
      • my68barracuda
        662
        272
        Dec 6, 2009
        Indianapolis IN
        Local Time:
        8:48 PM
        Using standard 73 and up
        upper control arms
        And the stock 68 lower control arms, the lowers have been boxed on the bottom side. And my existing calipers are sliders.
      • mcodecuda
        mcodecuda Senior Member
        467
        69
        Sep 17, 2007
        Mooresville, NC
        Local Time:
        8:48 PM
        I’m a firm believer in using stock parts whenever possible. I took the bottom of my A-body big block k-frame off and welded on the bottom of 73 k-frame. That way I could run the 73 style sway bar thru the k-frame and 73 lowers. No need to swap spindles, no need to change brake hoses. Run with the design that was designed by Chrysler.
      • RedFish
        RedFish Well-Known Member
        23,295
        2166
        Sep 5, 2007
        Local Time:
        7:48 PM
        I haven't seen a stabilizer bar that had its end links attached to upper arms. Can't imagine length of end links or how it clears a front mounted caliper. Difficult to keep up with aftermarkets creations I guess. Please post pics if/when you get this installed.
      • RogerRamRod
        RogerRamRod The Older I Get, The Faster I Was
        825
        412
        Jul 5, 2011
        Chesapeake VA
        Local Time:
        7:48 PM
        My guess is he meant upper side of LCA
        • Agree Agree x 1
        • 72bluNblu
          9,364
          3436
          Nov 28, 2008
          NorCal
          Local Time:
          5:48 PM
          All the A-body lower control arms are basically the same, the only real significant difference by year is the location of the sway bar tabs. Since you’re using the Hotchkis bar and sway bar tabs the year of the LCA doesn’t really matter, the Hotchkis tabs don’t mount in the stock 68-72 location.
          The Hotchkis sway bars are light years better than anything ever made by the factory. In many cases the factory designs are outdated, they were never intended to be used with radial tires for example. And that's a big deal. Just because the factory did it a certain way 50 years ago doesn't mean it's still the best way to do it. Heck it doesn't always mean it was the best way to do it THEN, remember Chrysler was there to make money, not the absolute best product possible. Lots of designs were used because they were adequate and less expensive, not the best.
          And I don't know why we're still talking about interference. There shouldn't be any with the Hotchkis bar and the sway bar tabs that go with it, the calipers should be able to be front mounted with that set up.
          Heck, even the stock 68-72 sway bars with the stock 68-72 location sway bar tabs can be made to clear front mounted calipers. It takes some trial and error and shortening the end links, but it can and has been done.
          • Agree Agree x 1
          • Valkman
            809
            234
            Sep 13, 2012
            NC
            Local Time:
            8:48 PM
            I had interference is with my ADCO bar, and I figured he was having the same issues with the Hutchins bar. Can the OP post a picture of what they are talking about?
          • 72bluNblu
            9,364
            3436
            Nov 28, 2008
            NorCal
            Local Time:
            5:48 PM
            The Addco bars use the stock sway bar tab location, which is the issue with the 67-72 sway bar interferening with the front mounted 73+ calipers. The Hotchkis sway bar useds a completely different sway bar tab location.
            Remember, the stock location for the 73+ calipers was to the front, they cleared the 73+ sway bars because the 73+ tabs aren’t in the same place as the 67-72 sway bar tabs.
            • Agree Agree x 1
            • Dennis H
              Dennis H Well-Known Member
              183
              196
              May 29, 2013
              San Jose
              Local Time:
              7:48 PM
              990D1630-1E69-420A-8038-1837BC98114C.png It’s what they do. Everything interferes with everything. Knocked the Zerks off in just a few days. Need to be contortionist to remove oil filter now used to be easy. Don’t let the sticker be your guide ;). This bar could be mounted either way.
            • 72bluNblu
              9,364
              3436
              Nov 28, 2008
              NorCal
              Local Time:
              5:48 PM
              Well zerks aren’t designed to be curb feelers.
              What’s the part # on that bar? Because the current A-body design doesn’t look like that. It’s not the same bar as what the OP listed.
              • Agree Agree x 1
              • Dennis H
                183
                196
                May 29, 2013
                San Jose
                Local Time:
                7:48 PM
                Sorry, it a B Body. Zerk should not the lowest point. Not a track car, real world drivability often compromised by upgrades.
              • 72bluNblu
                9,364
                3436
                Nov 28, 2008
                NorCal
                Local Time:
                5:48 PM
                B-body. So, nothing at all like the car or the sway bar we’re talking about.
                As for the zerks, yeah, it would be helpful if they weren’t on the bottom of the mounts. But they only stick out like a 1/4”. They’re definitely not the lowest part of the car, just too low for a parking block. But like I said, you’re not supposed to use your sway bar mounts as curb feelers anyway. Bad habit and practice to get into.
                • Thanks! Thanks! x 1
                • Dennis H
                  183
                  196
                  May 29, 2013
                  San Jose
                  Local Time:
                  7:48 PM
                  Yep, should drive an A Body so don’t have to nose in an 18 1/2 foot car. But you’re right, I’m a lousy parker.
                • MileHighDart
                  MileHighDart Well-Known Member
                  3,294
                  2054
                  Jun 3, 2004
                  Lyons, CO
                  Local Time:
                  1:48 AM
                  I just put that same Hotchkis bar on my ‘68 dart a few months ago and I love it!
                • my68barracuda
                  662
                  272
                  Dec 6, 2009
                  Indianapolis IN
                  Local Time:
                  8:48 PM
                  The Hotchkis bar arrived today,
                  It may be a few days, I will get it mounted and post photos.
                  • Like Like x 1
                  • GMachineDartGT
                    1,492
                    179
                    May 9, 2006
                    203 West Hills Road
                    Local Time:
                    8:48 PM
                    Hotchkis uppers are never on my suggestion list.
                    • Like Like x 1
                    • my68barracuda
                      662
                      272
                      Dec 6, 2009
                      Indianapolis IN
                      Local Time:
                      8:48 PM
                      Finished up the Hotchkis sway bar install yesterday.
                      The only tricky part was getting the spacing right on the tabs that go on the lower control arms.
                      I used a magnet to hold the tabs to the control arms, built up the sway bar with the end mounting bolts,
                      then ran a plumb down the sway bar tab mount holes to the sway bar bolts to correctly locate the tabs.
                      As part of the same project I also installed a USCT core support.
                      It all went well. No interference with the front mounted calipers.
                      • Like Like x 1
