Hotter Spark Plugs
Electrical and Ignition
  1. dICKj
    dICKj Well-Known Member
    84
    64
    Sep 25, 2018
    Kilgore, TX
    Local Time:
    1:08 PM
    Can l go to a hotter plug if my plugs are all blackened.
  2. TT5.9mag
    TT5.9mag Two atmospheres are better than one
    1,785
    1774
    May 5, 2016
    So cal
    Local Time:
    11:08 AM
    You can but before you do you should figure out what exactly is blackening them or the new plugs will look the same.
    Blackened from what? Take some pics.
    • Agree Agree x 2
    • toolmanmike
      toolmanmike Moderator Staff Member FABO Gold Member
      61,526
      50134
      Jan 18, 2006
      Iowa
      Local Time:
      1:08 PM
      Probably not because they are a heat range too cold. Possibly choke staying on, carb bleeding over due to too much fuel pressure or a bad needle and seat and/or float with a hole in it. Holley carbs with a blown power valve can run rich as well. A slim chance you could have a bad coil. Slim possibility.
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      50,883
      19613
      Oct 14, 2010
      Idaho
      Local Time:
      11:08 AM
      ............Or you checked them before they had time to normalize or the engine cooling system has a problem and is running under temperature
