abdywgn
dismantler
Levrack | Home | A place for all your storage.
Levrack is designed to fit your workflow. From garages to manufacturing shops, fire stations to schools, Levrack fits any space.
was the "workbench" custom made? that looks slick! I think the tallest racking I have is 8 foot but I put sheet metal up top. Much lighter and easier to get down while on a ladder.I know it's a bit of a different idea but I made my bench entirely out of pallet racking. The racks above the bench will literally hold tons of weight, it's what they are made for. The racks were a couple hundred bucks off CL. I had them sandblasted and then I spray painted them. I can understand the appeal of the Levrack thing but IMO it might be less than ideal if/when you're dealing with heavy and/or odd-size stuff.
Please ignore the mess, it's a working shop.
This is just after I built it. Eventually I built a shelf across the whole length of the back of the bench.
Thanks. yes, the bench was custom made. I got the table tops (36" x 96")through Grainger at my work. I had to cut the flange along the bottom edges to fit which was a PITA, it' not the best cutting job. I welded square tubing to the bottom so they would sit in the rack beams. the other goal was to make it so that if something like a transmission was on it it wouldn't make loud metallic noise when it was moved around. It was a project!was the "workbench" custom made? that looks slick! I think the tallest racking I have is 8 foot but I put sheet metal up top. Much lighter and easier to get down while on a ladder.
how is the board attached to the wall that holds the chains/strap/block n tackle?Not finished yet, but I don't like shelf legs unless absolutely necessary. Depending on how you anchor them to the walls these can be 24'' deep using Walmart brackets.
View attachment 1716318788View attachment 1716318791View attachment 1716318790View attachment 1716318789View attachment 1716318792
The 4x4 is 12 inches long. That one has 2 bolts through it secured with nuts on the outside. The 2x4 has 4 inch wood screws attaching it to the 12inch. That keeps it off of the wall allowing me to hang the chains.how is the board attached to the wall that holds the chains/strap/block n tackle?
I like the "ladder" to get to the top shelves. Had one from work they tossed out after being hit by a forklift. It wobbled a bit too much on the uneven floor for my liking.Yes, in this first picture that's 2 full salvaged quarter panels for scale
View attachment 1716319098View attachment 1716319099View attachment 1716319100View attachment 1716319101
I got luck. A buddy is a machinist at a local manufacturing plant and OSHA changed the standards for how steep the ladder was (new ones are 4 feet deeper) so 3 of his friends got these for their shops for free!I like the "ladder" to get to the top shelves. Had one from work they tossed out after being hit by a forklift. It wobbled a bit too much on the uneven floor for my liking.
either as party area or library. endless possibilities.I have a small shop, about 27x29. I would love to have a mezzanine. I think.
OH COME ON Party or Library?????either as party area or library. endless possibilities.
but all that stuff up top can get heavy...either quantity wise or heavy parts themselves. 'sides, getting older, may not even want to walk up more stairs!OH COME ON Party or Library?????
Parts Storage, You can never have enough parts storage space
So can 20 people especially if they are dancing in unison.but all that stuff up top can get heavy
I built one in my out building, it is an unorganized mess, even with the boxes label.I have a small shop, about 27x29. I would love to have a mezzanine. I think.
Isn't it great! We get to mess with them from behind the grave!When I die, my kids will call me a hoarder
My buddy at work say I should start selling ****, I said I don't need the money, this was just today.Isn't it great! We get to mess with them from behind the grave!
sure it is until your wife says "I'll kill you if you die and leave this mess for me to clean up".Isn't it great! We get to mess with them from behind the grave!
