Dont know about the factory, but you should......
Here is my recipe: I try to run it approx. 20 minutes between 1600 - 2800 rpm's, and I usually do this by ear because I'm under the hood.
Here are a few tips:
1. Have someone there to help watch & help. They will help look for leaks, radiator level, heat gage, and hand you something if needed, etc. I had my teenage son help on the last one, but your wife can help just as much. Just give her her a few heads up....
2. It isn't a bad idea to have a garden hose handy incase the temp begins to get uncomfortable, you can put a nice mist on the radiator.
3. leave the distributer somewhat loose so you can "smooth it out" by turning it a little so it doesn't have to be shut off.
4. Use a carb that you know is in good working order.
Should your car shut off or you need to shut it off, get it going again and continue the break in procedure. I'm sure I've left some things out..... Remember, I'm a hobbiest, not a professional shop. I've done this a few times through out my years, but not daily or weekly like a machine shop. I've never lost a lobe, though...
