Rapid Robert
I was thinking that there would be a panel the unbolts that lets me get to the wiper linkage like on my ram van but that area is an solid extension of the firewall & no access there. thank you for your time. RR
Did my 75 a couple years ago. No shortage of cuts and scratches when I was done.Yep,,,under dash only .
I had to do that last June when I purchased my 73 ,,,,worked out well .
I have pics if you have a few questions of how the rods go back together ?
Tommy
Removing the instrument cluster does help some, you'll need to drop the steering column to get the cluster out, extra work, but at least then you kind of can see what you're doing and be sitting, instead of laying across the seat, contorting your back. Unless you enjoy that sort of thing.
I did my 70 Dart years ago when I was much younger, and it had no interior in it.
Absolutely!! Unless you're 4 feet tall and a contortionist, taking that seat out will make your life much easier.suggested first step - remove front seat...
But where's the fun in that? Plus the memories!Absolutely!! Unless you're 4 feet tall and a contortionist, taking that seat out will make your life much easier.
Shoulda ordered 4 pair. Better to have them and not need them than need them and not have them , especially when it's plastic pieces that can be damaged during reassembly.Yikes! very comprehensive info & very much appreciated. I googled the correct Dorman bushings for this & it gave me 49440. I just ordered 2 pairs from Ebay. the pass wiper blade is nonop. Might be awhile before I can tackle this! thanks guys, you are the best. RR
Keep in mind that if the link disconnected at the RH pivot, that the link will still move back and forth when you turn the wipers on, possibly sawing through wiring or hoses. It might even jam breaking something else.I will go ahead & order 2 more pair. only the pass wiper is non op. I might let this slide for awhile!
Imagine being twisted like a pretzel working under the dash on the driver's side, and you get a bad cramp in your leg. It takes a minute to untwist yourself and get out of the car and on your feet. All that time the cramp is getting tighter and tighter. Ask me how I know.But where's the fun in that? Plus the memories!
When I was in my 20s and even 30s, I wouldn't bother - at 69 I sure do! If I had known how much easier it was rather than sitting backwards in the seat with my knees over the seat back and my calfs behind, I probably would have even taken the seat out then. As it was I made good money doing underdash work like swapping dash pads for folks that didn't want to do it themselves.But where's the fun in that? Plus the memories!
