How do I fix this? 65 Dart window
zephyr
San Bernardino
Help. how Do I get to this to reattach this window frame?
really fix it? or just hack it in? if you want to hack it in then epoxy it or jb weld it. it won't come off for a long time. Now to really fix it like the factory you need to get some glass setting tape. I typically use the 1/32 style since my quarter window channels are tight. (total of 1/16" when C channeled for fit) not the 1/16" which of course doubles to 1/8" when c channeled but yours might be slightly spread open and the larger stuff might be better . clean the channel of tape and goop. slide on the glass and decide if it's 1/16 gap or 1/8" gap. go from there . Amazon.com: glass setting tape
I like to use plain old black silicone since it is not as permanent as JB weld or epoxy and has been holding mine in place fine for more than a decade. To use the glass setting tape mentioned usually requires the glass be out of the door for this procedure.
