How do you get rid of a moonroof
Mopar Body and Trim
  1. Neal Zimmerman
    Neal Zimmerman Well-Known Member
    74
    11
    Jul 24, 2016
    Springfield Oregon
    Local Time:
    6:32 AM
    Just picked up a solid, clean, rustfree 2 door classic mopar, Too clean and complete of a car to pass up. One big problem. Somebody installed an ugly moon roof at one point. This must go. Any ideas? A carefully crafted patch panel with back up bracing and a vinyl roof over the top is what comes to mind. Anybody ever tried this.?? I'm not gonna put a new roof on the car, unless no other choice.
    Thanks , Neal
    • Agree Agree x 1
    • moparmat2000
      moparmat2000 FABO Gold Member FABO Gold Member
      20,170
      9496
      May 13, 2010
      Grand Tetons
      Local Time:
      8:32 AM
      Best way is a whole roof skin.
      • Agree Agree x 5
      • Joey4speed
        Joey4speed FABO Gold Member FABO Gold Member
        1,623
        1323
        Jul 17, 2018
        Coastal NC
        Local Time:
        9:32 AM
        curious, which Mopar did you get?
      • Dana67Dart
        Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
        7,902
        5495
        Jul 16, 2017
        Northern Colorado
        Local Time:
        7:32 AM
        All depends on how talented you are.
        You could hammer weld a patch in. Shrink the metal back to shape
        • Agree Agree x 1
        • geminimotors
          geminimotors Well-Known Member
          366
          286
          Nov 24, 2015
          Oakland
          Local Time:
          6:32 AM
          What car do you have? I think all a body roofs have a compound curve. I would use a piece from a donor car with a similar roof contour, flange the edges of the patch panel to overlap the hole and install from below. Maybe a Camaro or something has a similar curve? Definitely replace any structural bracing with parts from a donor car of the same body as yours. You might need one or more headliner bows also.
          • Like Like x 1
          • Neal Zimmerman
            74
            11
            Jul 24, 2016
            Springfield Oregon
            Local Time:
            6:32 AM
            I failed to mention which mopar i bought because its not an a-body. But since you asked its a 1965 Coronet 500 2 door hardtop. Beautiful car except for the damn moonroof
            • Like Like x 2
            • Dartsun
              Dartsun Mopar Dude
              2,141
              1927
              Feb 12, 2012
              Springfield Oregon
              Local Time:
              6:32 AM
              Hey Neal it’s Dustin, Aaron’s old friend hope your doing well.
            • Sublime one
              Sublime one 72 Demon FABO Gold Member
              6,038
              13450
              Mar 17, 2018
              Fargo
              Local Time:
              8:32 AM
              My Cuda had the obligatory butchered in sun roof. I made a cardboard pattern then cut out a very tight fitting patch. I put a bit of contour in it by hand before I welded it in. Then took my time skip welding cooling and welding trying to minimize the warpage. Then I did my best to relax weldment areas with a bucking bar and a hammer. It really sucked but I did not have the cash for a new roof skin. Once I got it as good as I could I smoothed it with bondo then put a nice vinyl top on it. I think it turned out well but it was a lot of work. The vinyl roof does not hide as much as you think it will. Be patient and really work on smoothing it out when done. I can send you a pix of mine if you like.
              • Like Like x 1
              • geminimotors
                366
                286
                Nov 24, 2015
                Oakland
                Local Time:
                6:32 AM
                Theres a 65 Belvedere in the parts car section of the classifieds.
              • 65Val
                65Val Average Length Member
                5,250
                1258
                Oct 14, 2005
                Victoria, BC, Canada, EH!
                Local Time:
                6:32 AM
                Neal...long time, no see!!!!
                • Like Like x 1
                • George Jets
                  George Jets 1967 Dart 2 Door FABO Gold Member
                  5,634
                  7726
                  Jan 18, 2019
                  Farmington MN
                  Local Time:
                  8:32 AM
                  Ever heard of 3M Panel Bond, has been used to put new quarters on.
                  Get a replacement part with the right curve to it and 2" larger than the moon roof hole. Then panel bond it in from underneath, no welding and no warping that is the big advantage of panel bond.
                  Then finish out the topside with Body Filler to get the final shape right. Prime and Paint, good as new.
                  • Like Like x 5
                  • 67Dart273
                    67Dart273 FABO Gold Member FABO Gold Member
                    51,578
                    20588
                    Oct 14, 2010
                    Idaho
                    Local Time:
                    6:32 AM
                    Every sunroof installer from the beginning of time should be neutered, skinned, and banished to the S end of Chile. I've passed up two otherwise decent A bodies because of the big hole in the top
                    • Agree Agree x 3
                    • RustyRatRod
                      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                      79,595
                      58103
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      9:32 AM
                      I agree 100%.
                    • moparmat2000
                      20,170
                      9496
                      May 13, 2010
                      Grand Tetons
                      Local Time:
                      8:32 AM
                      Ditto for everybody who ordered one of these cars new with a crappy assed vinyl top, or had one installed after the fact.
                      • Like Like x 2
                      • Agree Agree x 2
                      • 65 Dartman
                        65 Dartman FABO Gold Member FABO Gold Member
                        12,504
                        4115
                        Sep 24, 2006
                        Strasburg, VA
                        Local Time:
                        9:32 AM
                        My youngest son Was parting out a late 80’s VW Jetta with a manual hand crank sunroof. The curvature of the Jetta roof looked virtually the same as my 65 wagon. So we cut the Jettas roof off with every intention of splicing it into the wagon’s roof. @SNKEBIT was the one who gave me the initial idea with his sunroof conversion on his Barracuda. It just wasn’t to be due to the reinforcing ribs in the roof
                      • A56
                        A56 MoPar Affliction
                        5,406
                        14293
                        Jun 24, 2014
                        South of the Mason-Dixon Line
                        Local Time:
                        8:32 AM
                        I agree. I passed up a '69 A56 cuda 340 auto console about 11 years ago that was in San Diego for sale. Had an after market dealer installed 70's sunroof similar to what they installed on vans.
                      • George Jets
                        5,634
                        7726
                        Jan 18, 2019
                        Farmington MN
                        Local Time:
                        8:32 AM
                        If you are farmiliar with Auto Body Skills and tools you can take the Stepping Tool on your air hammer and step down the edge of the moon roof opening from the top.
                        Lay a piece of cardboard on the top and trace a pattern for the repair/replacement panel from inside with a dry marker.
                        Then cut the replacement repair panel a little bigger than the cardboard pattern you just made so that it fits nicely in the step down edge on the roof opening.
                        Now you can panel bond it in from the top, and should finish out a lot nicer being everthing is real close to where it should be.
                        • Like Like x 2
                        • dukeboy_318
                          dukeboy_318 FABO Gold Member FABO Gold Member
                          46,193
                          22207
                          Jan 19, 2007
                          No
                          Local Time:
                          9:32 AM
                          I've often wondered about the longevity of this stuff. Seems like any epoxy will weaken over time?
                        • Backally
                          Backally FABO Gold Member FABO Gold Member
                          576
                          315
                          Sep 4, 2011
                          Wisconsin
                          Local Time:
                          8:32 AM
                          • Like Like x 1
                          • krazykuda
                            krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                            60,427
                            26590
                            Aug 20, 2007
                            Orland Park, IL
                            Local Time:
                            8:32 AM
                            If you drive around and moon people through the moon roof, then maybe some of the locals and authorities will take up a collection for you to cover the moon roof.... :eek:
                            • Like Like x 2
                            • retroron
                              retroron FABO Gold Member FABO Gold Member
                              911
                              771
                              Apr 9, 2014
                              Livermore Calif
                              Local Time:
                              6:32 AM
                              How do you REALLY feel?
                            • moparmat2000
                              20,170
                              9496
                              May 13, 2010
                              Grand Tetons
                              Local Time:
                              8:32 AM
                              I have the same panel flanger they are using. Nice tool to have.
                              • Like Like x 1
                              • Ottmundr
                                Ottmundr 68 Fastback
                                7,967
                                13104
                                Oct 5, 2012
                                Sonoma
                                Local Time:
                                6:32 AM
                                Solar eclipse?
                                Keep it cool when welding in a patch panel, minimizing the amount of hammering and bondo. Anneal the areas you did your shaping.
                              • George Jets
                                5,634
                                7726
                                Jan 18, 2019
                                Farmington MN
                                Local Time:
                                8:32 AM
                                Nice Job in the video, that's what you call auto body skills.
                                Thanks for posting for all to see.
                              • 67Dart273
                                51,578
                                20588
                                Oct 14, 2010
                                Idaho
                                Local Time:
                                6:32 AM
                                I know. I could never have been a salesman, lawyer, or politician. If you ever meet me, you'll find that is just the way I am. I have been wrong, but what I tell you is what I believe. And I'm fairly opinionated LOLOL
                                • Agree Agree x 1
