68383GTS
How do you remove a slip in shifter handle. I tried using 2 butter knives at the same time and slip between the clip and handle with no luck.
Dadsbee is on the right track. Butter knives are way too thick. I use a couple pieces of shim stock around .040". Metal pallet strapping should be a good thickness and it should be hard enough. Piss poor design, the bolt in handles are much better.
I took my .011 feeler gage and clamped vise grips to the end and was able to wiggle and tap it in. Used a lot of wd40 also. It wasn't easy. Good luck.How do you remove a slip in shifter handle. I tried using 2 butter knives at the same time and slip between the clip and handle with no luck.
