How much hp and 1/8 ET
Mopar Racers Forum
  1. 68 barracuda 68
    68 barracuda 68 Active Member
    27
    5
    Sep 23, 2018
    Norway
    Local Time:
    11:02 PM
    hi, waiting on my engine getting finish, the combo is 408cid , mild ported W2 heads, TTi W2 headers, 830 holley,10,8:1 comp, comp cam duration 296 valve lift inn 0,649 exaust 0,651 rpm range 4200 to 7400. 727 tci transmission, dynamic 9,5 3800-4200 stall, 4,56 gear, 28-10,5x15 slicks. How mutch horsepower can i expect to have, and 1/8 ET weigt of the car is around 3000lbs
    • Like Like x 2
    • j par
      j par Well-hung Member
      13,285
      5958
      Jul 2, 2014
      Portland Oregon
      Local Time:
      2:02 PM
      If you've never drove a car like that I'd say your in for one hell of a ride!
      • Like Like x 2
      • Agree Agree x 2
      • moparcrazy
        moparcrazy Well-Known Member
        363
        46
        Dec 26, 2009
        America the Great !
        Local Time:
        4:02 PM
        500-550 HP & Depending on your suspension, 11.80-12.00 just my opinion. how many times have you been down the track also play's a bigger role in ET times, Good luck fun times ahead.
      • 68 barracuda 68
        27
        5
        Sep 23, 2018
        Norway
        Local Time:
        11:02 PM
        Well been driving 5,56 1/8 but that was a another car, next seasonn with be with my barracuda street legal, my hope is to drive 6,70 1/8
        • Like Like x 2
        • 68 barracuda 68
          27
          5
          Sep 23, 2018
          Norway
          Local Time:
          11:02 PM
          Been driving for some years, suspension is Qa1 and qa1 front
        • j par
          13,285
          5958
          Jul 2, 2014
          Portland Oregon
          Local Time:
          2:02 PM
          10-4.
          Cool your a new member and we have no background. And you guys over ponds like some crazy horsepower.
        • moparcrazy
          363
          46
          Dec 26, 2009
          America the Great !
          Local Time:
          4:02 PM
          I'm quoting 1/4 mile times, but your car only weighing 3000 LBS & better than stock suspension should have better ET's then what I mentioned, even faster then 6.70 IMO.
        • roccodart440
          roccodart440 Well-Known Member
          5,058
          4041
          Apr 19, 2010
          Local Time:
          5:02 PM
          If this is accurate it's very similar to my car which makes ballpark 500 at the crank (I only know what it makes at the wheels) and runs 11.70's in the quarter. That goes 7.40's in the 1/8th
          • Thanks! Thanks! x 1
          • 68 barracuda 68
            27
            5
            Sep 23, 2018
            Norway
            Local Time:
            11:02 PM
          • 68 barracuda 68
            27
            5
            Sep 23, 2018
            Norway
            Local Time:
            11:02 PM
            Im getting the engine tested and tuned at the flywheel, what does the calculator says about hp on my combo? Is wallace calculator hp at the flywheel?
            • Like Like x 1
            • moparcrazy
              363
              46
              Dec 26, 2009
              America the Great !
              Local Time:
              4:02 PM
              That's a good question, I've often wondered the same, but comparing it to my build I would say Yes, its flywheel comparison?
            • B3422w5
              B3422w5 Well-Known Member
              678
              479
              Feb 9, 2017
              Portage michigan
              Local Time:
              5:02 PM
              Should run 10.50’s easy enough. 6.60’s in 1/8
              Obviously more convertor would help, and not sure exactly what cam you have
            • 68 barracuda 68
              27
              5
              Sep 23, 2018
              Norway
              Local Time:
              11:02 PM
              That would be perferct, yes im also woried about the converter, but will make some runs in it if it goes 6,70 im happy with it, the class im going in is 6,70 Et. Here is my cam:
            • skrews
              skrews Well-Known Member
              1,260
              627
              Jul 20, 2012
              Washington state
              Local Time:
              2:02 PM
              525hp 6.7s @ 100 in the 1/8
              • Agree Agree x 1
              • justinp61
                justinp61 Well-Known Member
                1,182
                480
                May 15, 2009
                Local Time:
                4:02 PM
                I don't think 6.70's will be a problem with what you listed, more converter will help. I went high 6.50's with less cam, 10.9-1, ported Edelbrocks, 727 with a 9.5" converter that flashed 5000, 4.10 gears and a 325 (28" tall) radial at 3260 pounds. If the heads are decent you could go faster than .50's.
                • crackedback
                  crackedback FABO Gold Member FABO Gold Member
                  18,055
                  2192
                  Aug 7, 2005
                  92201
                  Local Time:
                  2:02 PM
                  ET is ALL chassis/converter!!!
                  What takes one person to go a certain ET, might take another 50-70HP less... Get the car to 60' like crazy and the ET will follow.
                  • Agree Agree x 2
                  • Hot Metal
                    Hot Metal '69 440 Cuda
                    270
                    96
                    Dec 21, 2014
                    UK
                    Local Time:
                    4:02 PM
                    Wallace is fwhp and @a mere 530hp with your car you have the potential for this when sorted>
                    60 Foot E.T. : 1.44
                    1/8 Mile E.T. : 6.55
                    1/8 Mile Trap Speed : 103.77
                    1/4 Mile E.T. : 10.38
                    1/4 Mile Trap Speed : 129
                    1/4 Mile Trap RPM : 7,069
                  • 68 barracuda 68
                    27
                    5
                    Sep 23, 2018
                    Norway
                    Local Time:
                    11:02 PM
                    Thanks, will give a update after the dyno results, hopefully in some few weeks
                  • bluefish
                    bluefish mopar dave
                    155
                    67
                    Dec 17, 2007
                    Mt.Morris MI
                    Local Time:
                    5:02 PM
                    Spot on. Those numbers are right on what my 408 ran with Indy heads, 11.25:1 and 8 " 5400 stall. 3300# race weight. Rest of motor was much like yours. 10.38@130 was my best pass ever. 6.66@103 was best 1/8. Should be fun.
                  • o1heavy
                    o1heavy 1974 dart sport
                    788
                    220
                    Jan 7, 2009
                    tarkington
                    Local Time:
                    4:02 PM
                    Which Indy heads ??
                  • Hot Metal
                    270
                    96
                    Dec 21, 2014
                    UK
                    Local Time:
                    4:02 PM
                    At 3300lbs you have stout motor that makes in the order of 585fwhp:thumbsup:
                  • bluefish
                    bluefish mopar dave
                    155
                    67
                    Dec 17, 2007
                    Mt.Morris MI
                    Local Time:
                    5:02 PM
                    360-1 with some port work . They flowed 325@.700".
                  • bluefish
                    bluefish mopar dave
                    155
                    67
                    Dec 17, 2007
                    Mt.Morris MI
                    Local Time:
                    5:02 PM
                    Long story short. I freshened it with 13.5:1 compression and max ported the heads. It came apart in a big way on the dyno. Had a oiling problem I never figured out. I now have a 511 with E MW heads.
                  • MikeD
                    MikeD Well-Known Member
                    150
                    48
                    Dec 16, 2004
                    Nottingham, England
                    Local Time:
                    10:02 PM
                    roccodart440
                    I don't know how much your car weighs but my old full weight 70 Challenger street car ran 11.83 at 113 with around 450-475 hp with 440 ported stock heads, hyd cam.
                  • roccodart440
                    5,058
                    4041
                    Apr 19, 2010
                    Local Time:
                    5:02 PM
                    not sure. the scale house has never been open and I don't have scales at home. I'd guess 3200+me
