moparstud440
On a pretty well sorta out combo that has a good working chassis, roughly how much flywheel HP will it take to make a 3200lb car with driver go 6.40's in the 1/8th?
It should be an easy one for the Wallace calculator...On a pretty well sorta out combo that has a good working chassis, roughly how much flywheel HP will it take to make a 3200lb car with driver go 6.40's in the 1/8th?
Thanks, kind of hoping someone that has dynoed their motor and have track results will chim in as well.It should be an easy one for the Wallace calculator...
I'm not a big believer in a dyno for anything more than a tuning device. honestly I would think about 425 to 450 horsepower at the wheels with a very well sorted out suspension at that weight should get you there...Thanks, kind of hoping someone that has dynoed their motor and have track results will chim in as well.
