I'm now to the point of putting the A/C system on the Dart. Can someone tell me how much Ester oil to add to the system? I drained the compressor and flushed the system, new dryer so the entire system is empty.
You should make sure you flushout all the old mineral oil with a special fushing solution availabe from most big auto parts stores. Then with a new drier and with an empty compresser that was either new or flushed out ( remember to replace the crankshaft gas seal and lube it with the new oil type) it needs 10 to 12 ounces of oil. This came right from a Chrysler service book.
