1. greymouser7
    greymouser7 Vagrant Vagabond “Veni Vidi Vici” FABO Gold Member
    3,260
    2570
    Apr 17, 2010
    78002 down the road from Atascosa, Texas
    Local Time:
    1:18 AM
    If I buy a 360 and want to attach an external balanced car flywheel, how do I figure out the correct attachment/mounting configuration (I guess out six choices?) ?
    thank you!
  2. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    41,664
    9317
    Oct 14, 2010
    Idaho
    Local Time:
    11:18 PM
    • Agree Agree x 2
    • adriver
      adriver Blazing Apostle
      7,463
      4109
      Jun 1, 2007
      Where the red fern grows
      Local Time:
      2:18 AM
    • adriver
      7,463
      4109
      Jun 1, 2007
      Local Time:
      2:18 AM
      There's a chart somewhere.
      I looked at it and figured it was sort of sketchy since it shows holes but doesn't give a depth or bottom configuration.
    • JBurch
      JBurch Well-Known Member
      1,803
      926
      Oct 17, 2009
      Owego, NY
      Local Time:
      2:18 AM
      The flywheel will only bolt on correctly one way for, all six bolts to line up
      • Agree Agree x 2
      • Thanks! Thanks! x 1
      • greymouser7
        3,260
        2570
        Apr 17, 2010
        Local Time:
        1:18 AM
        No sir. I have an EXTERNAL Balanced flywheel. I just did not want to line it up incorrectly, mount the trans to the engine, and find out later, & have to pull everything out again.
      • Frnknsteen
        Frnknsteen FABO Gold Member FABO Gold Member
        547
        336
        May 26, 2011
        Spencer, IN
        Local Time:
        2:18 AM
        Burch is right,.... It should only bolt on in one location. If you look at the drawing in post #2, and look at the six mounting holes, you'll notice that 2 of them are offset, making them only line up in one position. I have the same thing on my 400 in my Barracuda. It would only mount on in one position.
        • Agree Agree x 1
        • JBurch
          1,803
          926
          Oct 17, 2009
          Owego, NY
          Local Time:
          2:18 AM
          To the OP.......It sounds as though you have the engine out of the car, you could have just hefted the FW up into place on the back of the engine and attempted to bolt it up, you had a 1 in 6 chance to get it the first time, had it NOT lined up you then had the opportunity to keep trying till you did get it right and LEARN something on your own, some times there is no greater satisfaction.
          A tip for when you torque up the flywheel bolts.....so that you are not chasing the flywheel as it turns as you try to tighten the bolts, slip a pin punch, screw driver(round shank), bolt, thru one of the pressure plate mounting bolt holes so it will come to rest against the block from the under side and not allow the FW to turn
