Hi, I am building a 5.9 magnum for use in my 71 Scamp and need to check pushrod length, but am finding a lot of conflicting information on the web about how to do this.
I have a regrind camshaft in the motor now, which has been degreed. I plan on reusing the stock hydraulic roller lifters. My heads have been assembled by the machine shop and are sporting new Hughes valve springs. i do have an adjustable pushrod length checker tool.
I am reading on the web conflicting information on how to check pushrod length. A common issue seems to be that the valve springs will compress the hydraulic lifter and give you a false reading. Some are saying you need to use either a solid lifter or soft checking springs. Other say you can shim your lifter. Some say Hughes has an adjustable lifter used for checking pushrod length. Then others are saying you need to check by using the lifters and springs you plan on running.
I am at a point in my build where I am ready to bolt my heads on, and would love to figure this out as efficiently as possible.
Can anyone give me the straight dope on how to check pushrod length with my set up? Step by step instruction would be hugely helpful! Thanks in advance!
