How to recondition "coated" interior panels?
Mopar Interiors
  1. Rod 69 Cuda
    Rod 69 Cuda Member
    24
    5
    Nov 14, 2019
    Massachusetts
    Local Time:
    1:46 PM
    How do I restore interior fastback panels? They are plastic/vinyl/rubber coated over tin. Do I use rubberized paint? Textured paint? One section has rust under the "coating" which is bubbling, can I sand the plastic/vinyl/rubber top coat away to get to the rust, treat it, then paint over with something? What is the best method to restore? Thanks
  2. 67dodgedartconv
    67dodgedartconv Well-Known Member
    453
    114
    Feb 22, 2011
    pass christian, mississippi
    Local Time:
    12:46 PM
    Have the same issues with mine. I chose to buy the carpet kit for mine even though they were not carpeted originally.
    • Like Like x 1
    • roccodart440
      roccodart440 Well-Known Member
      5,527
      4536
      Apr 19, 2010
      Local Time:
      1:46 PM
      They make a matte black, textured powdercoat.
      I'd have them stripped and done that way. I used it on my dash.
      • Like Like x 2
      • 4spdragtop
        4spdragtop Well-Known Member
        28,367
        8208
        Aug 28, 2009
        Wasting time here
        Local Time:
        12:46 PM
        Our fb is carpeted as well, but maybe try Plastikote black wrinkle.paint on 1 piece as a test.
        • Like Like x 1
        • Agree Agree x 1
        • 67dodgedartconv
          453
          114
          Feb 22, 2011
          Local Time:
          12:46 PM
          Sorry, my panels currently look like yours, but someone on here will have some pictures of carpeted ones from their car. You can order them pre-cut.
        • rklein383
          rklein383 Well-Known Member
          1,460
          373
          Dec 2, 2005
          Local Time:
          12:46 PM
          That is a great question and I don't know the answer. I found a nice pair for my 383-s in a junkyard many, many years back. It was a great day when I found them as they were in great shape, with no speaker hole cut out in them, which is quite common. Here is a picture of my 383-s I sold a few years back, had it for 25 years. Rod
          • Like Like x 1
          • 4spdragtop
            28,367
            8208
            Aug 28, 2009
            Wasting time here
            Local Time:
            12:46 PM
            Hi Rod, lemme do some digging for some previous pics. Cuda is currently in storage so I cant get any current ones.
          • Furious65
            Furious65 C-body Guy
            368
            51
            Apr 8, 2009
            Tucson, AZ
            Local Time:
            10:46 AM
            Not sure on the texture of the originals (I own a notch back) but there are a lot of things that can be done with the various bed liner coatings to get different textures. Eh, just an idea on something to look in to!
            • Agree Agree x 1
            • Vertex_Jeff
              Vertex_Jeff Undocumented Mopar Guy
              54
              106
              Nov 10, 2019
              Richmond IN 47374
              Local Time:
              1:46 PM
              Sorry to hijak - did you make that gauge cluster yourself? I'm wanting to do something similar for my '67. I'm not a fan of the factory ralley cluster - and would rather go aftermarket.
            • roccodart440
              5,527
              4536
              Apr 19, 2010
              Local Time:
              1:46 PM
              It was from a company that is no longer in business called rocky mountain dashes. Later it re-opened as PEak Dashes.
              There is another source to get them from located in this thread.
              Re: Peak Dashes
            • RedFish
              RedFish Well-Known Member
              23,894
              2597
              Sep 5, 2007
              Local Time:
              12:46 PM
              The pre 68 bucket seat backs and skirts were made the same, vinyl attached to steel with contact cement. I've repaired small cuts/various scars in the vinyl on those parts but I didn't have the rust issue. The carpet is probably your best route.
              • Like Like x 1
              • Vertex_Jeff
                54
                106
                Nov 10, 2019
                Richmond IN 47374
                Local Time:
                1:46 PM
                Thank you
                • Like Like x 1
