67all3
Member
Trying to repair the window function of my driver's door window (channel lining appears crushed). I've disassembled virtually everything on the door, trying to make "space" to take the glass/vent assembly to slide out. No luck. Even removing the felt strip (both sides of door top) did not allow enough space. Further, the bottom of the door glass has a blue-knobbed "nut" (?) holding the slide lift bracket onto bottom of the glass. Cannot determine how to disassemble that "safely" (without breaking the glass!). Maybe special tool? Hope someone has been successful with this task. Thanks, in advance, to all who have some ideas/solutions.
