How to tame a Comp 292/501 H cam
John Reeves
New Member
indiana
Hello,
I have a 1966 Barracuda S - built 360 , Run on 89 pump gas. built 904 , 3000 stall,ect, 1971 N case , 3.91 gears.
The cam is a Comp 292 H 501 lift.
Not a big fan of the RPM drop from park to drive. Would like to tame it some. Any suggestions?
I’m thinking of Rhodes lifters to help.
Thanks
More converter or more cubic inches. Could try advancing the cam some more (depending on where it is). Kinda is what it is,that is a big cam for 360 c.i.
How does it run otherwise?
Welcome to the forum!
Hello,
Thanks
I had a 340 with a 300 300 243@50 507 lift 108 106 rhoads lifters worked great with it
Yes, definitely would be good to know the details like heads, static compression, carburetion, and where the static timing is presently set at.
Just purchased the car a couple of weeks ago. Will follow up with the details.
Thanks for all responses. Life long Pontiac guy, just getting into Mopars. I have a lot to learn, so bear with me
When I read your thread title, Rhodes lifters were the first thing that came to mind.
Timing refinement might cure your rpm drop easier.
(More initial, less total in the distributor, play with vacuum advance, ported or full manifold)
Wow, I guess my timing suggestion is a bit late, lol.
That cam isn't what I would consider an idle friendly piece for an auto car.
Plenty of tune around it required and prefer a loose converter
First thing, put a timing light on it and hillbilly timing tape the balancer if it isn't already marked.
Best way to tame that cam in an automatic car with low compression is to replace it. All other ways of “taming” it are just a crutch because the engine builder put too much cam in it. That cam wants 10.5:1 comp and 3500 stall with 3.91 gears as a minimum in a 3000lb car.
More timing is the cheapest (free), quickest and easiest way to determine if that's the issue. It's not a crutch, either. If an engine needs more timing, that's what it needs. Why you fellas with these problems cannot just walk out to the driveway, loosen the distributor and give it a twist to see, I have no idea. I could have found out twenty times by now if more timing is what it needed. This isn't difficult. If you find it does need around or over 20 initial, you'll need to limit total mechanical timing somehow, before you actually drive it much, so keep that in mind. My old 75 F250 I just got back running has an older Crane Fireball that's pretty lumpy. I have it sitting on 37 degrees initial at idle at about 900 RPM. I also have the vacuum canister on manifold vacuum, so it pulls in about 20 extra at idle. It idles good, crisp and clean. It likes that much because it's a low compression Ford 400 engine with a lumpy cam, so it needs it.
I ran the DC292/292/108 cam. I didn't like it and it wasn't in my 360 for but one summer.
I initially ran it in at 108LSA; for the topend and Effective overlap. And it was awesome.
But with just 11.3Scr the bottom was soft.
So I advanced it 4* and got some bottom end,
but with a starter gear of just 2.66 x 3.55= 9.44, the bottom was still soft.
Well; I live 20 minutes from the nearest city, and at that time, I drove to work every day, so 3.55s were kindof my limit.
I advanced it sumore, and things were improving, but now the top end was gone.
I realized that I had made a mistake, and later in the year, I sold the slightly used cam.
>Here's what I learned;
That cam wanted a lot of bypass air. At one point, I was up to 1/8th inch holes one in each primary. Eventually I figured out that this was too much. So I soldered them up, moved over, and went back to 1/16. which was too small. 3/32 was about right.
1) Convention says that cam needs 20ish degrees. But, at 20*, I couldn't drive that cam slow enough to parade with it.
2) here's what happened to me at 20.
The engine made so much idle power it was crazy. But, she wouldn't idle down until the throttles are nearly closed. So then 800rpm was 6.8 mph, and that was as slow as I could drive without riding the brakes. But when I rode the brakes, the engine pulses were so strong that the chassis began bucking, and it could get violent.
I wanted to get down to at least 4mph, which would be 470rpm.
3) I pulled the "standard A833" and swapped in the "overdrive box", to see what a 3.09 low would do. That got me to 5.85mph at 800
4) by now, I knew I was never gunna get there with 20* of Idle timing. So, in the interest of expediency, I reset the timing to 5* advance; yes, 5*..
This got me down to 550rpm=4.0 mph/ close enough; in gear, the engine had just enough power to pull itself on hard, level, flat ground with not much extra, and, the bucking was gone.
Of course, at 5*, I had to open the throttles quite a bit to idle on, and that's when I discovered that two of 1/8th " holes, one in each primary was too big. I fixed it.
So now I could parade.
But the risk of stalling in traffic was too high, so, as a daily, I ran it at 12 to 14.
The thing is, that I had discovered that at 550 rpm, that 292 cam was sounding mightyfine.
5) My solution was to procure a dash-mounted, dial-back, timing module. Which I set so that I could electronically add up to 9* of retard to 6* of advance, on top of where the Distributor was set, right from the driver's seat, which did NOT affect the T-slot sync. This solved two problems for me;
I got down to 4mph for parading, and I now had the possibility to run up to 60degrees of cruise-timing. UP TO.
6) But I had already decided that this 292 cam was not for me, so, as Winter approached, I pulled the Powertrain.
7) if you've paid attention, you should have heard me say, that my 367 at 11.3 Scr and the 292/108 cam, would in fact idle down to 550rpm, in gear and pulling itself, with just 5*..
With an automatic, you don't have to go that low; but, I guarantee that if you did, it would END your rpm drop.
Personally
I would start at 10 degrees and retune the Idle-circuit, to work with that, with the idea that, if you can make that work, try 2 more degrees. BUT
8) the ONLY reason to run lots of Idle Timing, is cuz it makes low-rpm power, in cylinder-pressure handicapped engines. That's it.
But you have a 3000stall, and 3.91s so then, yur engine NEVER has to pull from a low rpm. SO then, there is NO logically justifiable Reason to run so much initial..
9) Here's what I did, to get the low-rpm power back;
I installed a 2-Step timing curve that jumps the timing up fast, from 900 to 2800, then slows down to end at ~3400, so that I can run 87E10 gas full-time. AND
I modified my VA to bring in 22 degrees , fast and hard. This works really well with retarded Idle timing, which already has a large amount of throttle-opening, so, the Spark-Port is activated quite early, in time. Thus, at Part Throttle, My engine could be seeing up to 42* at 2000 rpm, 50* by 2800. My engine is NEVER lazy. It never detonates, and now, with a smaller cam (230/237/110) it still goes 93 in the Eighth at 3457 pounds at 900ft elevation. This engine now has over 100,000 miles on it.
10) the point I'm trying to make is this; How much is a new convertor gunna cost. versus retarding the timing to no more than 14Idle.
11) don't forget, that if you change your Idle-Timing, you will need to at least check your Power-Timing.
12) if you have iron heads, you may not get away with less than 91 gas, at WOT. This will be heavily dependent on your Effective cylinder pressure.
Happy HotRodding.
You definitely need initial timing close 20or above but that will require recurving your distributor . You don’t want a total of 42+ after you change the initial. Research how to recurve a mopar distributor. It’s not that complicated .
And your compression must be pretty low if you can run 89. Like Rusty said the cam will work much better with 10:1 + compression.
Then you will most likely have to do some carb work .
Right, but he can advance it temporarily and see if that straightens it out. Kinda what I was saying. I agree though, it will take a multi facetted tuning regime to git r done, but I think he can do it.
It needs three things:
- Rhoads lifters
- more timing at idle.
- a prayer to Allah.
I would try the Rhoads first, because how well they work will affect how much idle timing will be reqd. I would expect that cam to need 30ish for best idle.
I’d be interested in knowing-
-Timing, idling in gear
-manifold vacuum, idling in gear
-cranking compression,engine warm, throttle open
-what is the carb, does it have 4 corner idle?
Clearly, the simplest, easiest, quickest and cheapest (free) thing to do here is pull about 20 degrees initial timing in it and see how it runs. But, let's replace the cam, lifters, raise compression and everything it probably doesn't need.
Cheapest thing is initial timing. I run 26 in my 408 with a total of 34 not including vacuum advance. Next would be advance the cam to 104 ICL .
I put a Lunati Bracketmaster II which has 292 duration in my daughter's car with a stock compression 360 and had the same issue especially with the A/C on. I put a set of old PAW Super Stock lifters in it which work on the same principle as the Rhodes lifters and it works great. It has great throttle response and acceleration. Sounds like a stock 340 idling now. The only thing is that they are noisy.
