[FOR SALE] Howard's big block solid flat tappet cam & lifters
69GT
Metro Detroit
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along and the engine being built but I changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand but it never was run and is essentially new. $350 + shipping. I also have a new set of Comp Cams 973-16 inner valve springs I was going to use with this cam and Edelbrock RPM heads that I am asking $45 for.
https://www.summitracing.com/parts/HRS-CL722322-08
Mechanical Flat Tappet Camshaft & Lifter Kit; 1959 - 1980 Chrysler 383-440 3600 to 7600 Howards Cams CL722322-08 | Howards Cams
https://www.summitracing.com/parts/cca-973-16
