I have a set of Hughes prepped 2.02 1.60 EQ heads. They have magnum intake bolt pattern. Hughes 1110 springs are installed. I removed them to swap to aluminum heads. I put approximately 1,000 miles on them and had zero issues. I think Hughes said the springs coil bind at .620 but they recommend .540 max lift due to springs pressures. I used a 218/222 @.050 duration, .539/.549 lift hydraulic roller cam. The heads cost $1232 and the spring kit installed was $280. These heads have zero issues and I’ll throw in the used but good stock magnum rocker and head bolts if wanted. The head bolts were bought new and have the same mileage as the heads. I also have a new set of rocker studs and guides if adjustable Chevy roller rockers are desired.
Also have the Hughes cam mentioned available for sale. No issues with the cam, just went bigger.
Asking 1,100 for the heads plus shipping and I’ll throw in the stock rockers, or studs and guides for roller rockers. Located in Oklahoma City. The last set of cast iron small block heads I sold cost just under $100 to ship.
