[SOLD] Hughes Hydraulic Roller Lifters for LA Engines, Brand New
69_340_GTS
Torrington, CT
Hughes Engines Hydraulic Roller Lifters #5321 for LA Engines, Brand New.
This is for a set of 16 lifters.
These are a special set of lifters which DO NOT require any block grinding to drop-in. Designed for stock blocks, these lifters will not work in aftermarket R3 blocks.
And they can be installed with the cylinder heads still on the block.
These are oil thru lifters and will oil through the pushrods if you need them to. The oil band has been lowered so that the small blocks with the chamfered lifter bores no longer have to sleeve the lifter bores. Asking $275.00
Located in Torrington, CT. I will ship within USA for $15 extra.
I will take them if you would ship to Canada, I will pay the additional shipping.
If you can't ship to Canada I will take them.
